![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 10, '10 From MA Currently Offline Reputation: 37 (100%) ![]() |
You really don't need the bracing, especially if nothing is ever going to be sitting on top of it, like snow or people.
This post has been edited by mkernz22: Nov 19, 2015 - 11:18 PM |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 23, '12 From Warrior, AL Currently Offline Reputation: 0 (0%) ![]() |
Plus cutting out such small sections and tacking the bracing back down it probably won't make any difference at all to the overall structure of the hood anyway.
Then he'll have a limp hood, and that's not good for anyone.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 22, '06 From Columbia, MD Currently Offline Reputation: 13 (100%) ![]() |
yeah he probably may. the bracing is there for a reason.
1. hood crumple zones in the case of an accident. Itd be better to have it crumple than blade through the windshield (unlikely tho) 2. its an aluminum hood any if he removes itll basically be aluminum foil form a small dimple dome in the hood just for the oil cap. uber custom. best option? but it may look a little odd This post has been edited by Tigawoods: Nov 22, 2015 - 8:42 PM -------------------- ![]() 1995 GT::::Diffusing the Situation エキサイティングカーレーシングチーム! march 2010 COTM : 6GC feature 2014 : january 2015-2016-2018 COTM |
The bracing is there for a reason, steel hoods with removed bracing are flimsy enough much less aluminum. When I went from the standard Firebird hood to the shaker hood it was like, oh this is fairly solid to hey look I can flex it by hand... and it still has the bracing except for what was cut out for the shaker. Of course the shaker hoods are notorious for popping the seam filler used to hold the bracing to the hood skin, if I end up keeping it I'll re-adhere it before painting.
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Apr 17, '10 From U.P. michigan GO STATE Currently Offline Reputation: 3 (100%) ![]() |
just an idea, although a lot of money. what about a carbon hood? i don't think there is bracing under those
-------------------- It takes 8,460 bolts to assemble an automobile, and one nut to scatter it all over the road.
![]() Celica: The name is derived from the Spanish word for "heavenly" or "celestial". Back-2-Back July COTM 15&16 |
just an idea, although a lot of money. what about a carbon hood? i don't think there is bracing under those there is. They are just fiberglass copies of regular hoods with a layer of CF on top. TRUE CF hoods usually dont have a skeleton...but thatd have to be custom layed. -------------------- ![]() 1995 GT::::Diffusing the Situation エキサイティングカーレーシングチーム! march 2010 COTM : 6GC feature 2014 : january 2015-2016-2018 COTM |
If there is bracing in the way then F the bracing.
Stop being a bunch of nancies. Can you snap a pic of exactly where under the hood it's hitting ? -------------------- |
The bracing is there for a reason, steel hoods with removed bracing are flimsy enough much less aluminum. When I went from the standard Firebird hood to the shaker hood it was like, oh this is fairly solid to hey look I can flex it by hand... and it still has the bracing except for what was cut out for the shaker. Of course the shaker hoods are notorious for popping the seam filler used to hold the bracing to the hood skin, if I end up keeping it I'll re-adhere it before painting. Mine was sturdy enough without the bracing and it had two feet of snow on it at one point ![]() |
Stop it.... Lol... Whats done its done.....
Got a oil cap from fleabay 35B3A3BE ![]() Chopped it.... 9A98E5E0 ![]() Then went crazy... 52900E78 ![]() A little more..... B250BD30 ![]() Then visual inspection... D938B42D ![]() 29D9764D ![]() Is closing with the spacers. Then. Fed the tranny... 5AB11965 ![]() And the money shot. Clearance.... 11205434 ![]() Believe it or not. The crossmember actually is lower than the pan.... Test drive.... Soon.... This post has been edited by njccmd2002: Sep 25, 2017 - 1:26 AM -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Doing little bits here and there. Today i did the passenger seat. Woot woot. Had no seat. Lol
47A57485 ![]() After which i had a puzzle game... C1D96848 ![]() And ended up stock tachometer 77E2C291 ![]() Beams tach will be up for sale. And ther proceded to do the tach adapter.... 4C958FC1 ![]() Bought a dakota digital adapter. More to come soon This post has been edited by njccmd2002: Sep 25, 2017 - 1:27 AM -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Enthusiast Joined Feb 13, '16 From San Diego Currently Offline Reputation: 0 (0%) ![]() |
This is amazing
drained my power steering fluid, and put new one in it...
D8899BC2 ![]() over the past few days... 5B4B5C0C ![]() CED39684 ![]() cleaned them both.. and installed today.. installed with rapid bleeders... 8C981D8D ![]() ordered a simple radio... again... i gave away last one i had. needed a digital media radio F1F000A4 ![]() This post has been edited by njccmd2002: Sep 25, 2017 - 1:49 AM -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Looks great! I hope I get to see it at the spring meet!
Love it. Small. But what i need....
33F4579B ![]() BAB37C62 ![]() This post has been edited by njccmd2002: Sep 25, 2017 - 1:50 AM -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Today finally wired in the amp. Im happy to report the 8 inch woofers sound great...
A38CEAA7 ![]() BCFDC856 ![]() Sound system 2 years in the making lol.... While i was there.... 49E1B2DC ![]() Wired in the dakota digital adapter.... A036F3B5 ![]() And tucked it in... E8EF9342 ![]() Now the tach works.... C4679879 ![]() Need to tackle the battery light, the fuel pump and a/c system.... This post has been edited by njccmd2002: Sep 25, 2017 - 2:14 AM -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
so long for the limited edition sticker...
F2677DA2 ![]() 681D08BB ![]() fixing the holes.... EC98E4EC ![]() 72265FD1 ![]() 480FAD6F ![]() and got the roll bar in.... not sure still... 5105CF59 ![]() This post has been edited by njccmd2002: Sep 25, 2017 - 2:16 AM -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
But without the sticker it's no longer special.
![]() -------------------- 2001 Miata LS 5-speed
Lo-Fi Version | Time is now: July 21st, 2024 - 9:33 PM |
