> Anyone know how to put in new reverse lights?, Friend gave me blue reverse lights
post Feb 4, 2003 - 12:13 PM
celicagt94
Joined Feb 3, '03
From Maryland
Is there any easy way to put them in without having to take whole tailight out and rip out glue?
post Feb 4, 2003 - 1:55 PM
Tony-94
Joined Dec 17, '02
From UK
You mean blue bulbs to fit the rear taillights? You will have to take the lights off to change the bulbs (access is blocked by the metal panel at the back) but it's pretty easy - just 3 bolts on each unit.
There wasn't any glue or sealer on mine - they just came out.
You might need to remove the trim that fits in the boot at the back of the car to get to the bolts though.
This post has been edited by Tony-94: Feb 4, 2003 - 1:56 PM
Facelift bumper-foglights-clear indicators, clear side repeaters, 16in O.Z alloys, stainless steel grill. JDM facelift tail lights. clear sidelights. Retro-fit A/C conversion. APEX performance springs. Remus exhaust. K&N performance filter. KYB excel G shocks.
Hyundai coupe Mk 3 (US Tiburon) leather seats. Gen 7 s/wheel. SR black vinyl door cards. Late spec spoiler-less tailgate with 3rd brake light.
post Feb 7, 2003 - 5:14 PM
Charlie97L
From North Bethesda, MD
QUOTE (celicagt94 @ Feb 4, 2003 - 10:13 AM)
no, no, no, you don't unglue a light assy to change the bulb!! AH! ok, take off the rear trunk panel, unbolt the tail lights, and pull them out... and the bulbs twist out.
however, just so you know, any color backup light other than white is illegal and may get you a ticket... especially blue, only law enforcement have blue lights on their car. so just check before you go in reverse... also, with a non-white color, you won't be able to see jack behind you at night. just FYI.
1994 Lexus ES300
1989 Supra Turbo
1990 RHD ST185RC - JDM Spec
post Feb 7, 2003 - 7:54 PM
jontechie
Joined Oct 25, '02
From London- England
Charlie and Tony have it pretty much covered, on the rear panel in your trunk on
each side there are 3 plastic plugs with light symbols on them.Twist pull these out and you'll find a recess in which you have to unscrew a nut on a long bolt shaft.Once these are out the light cluster will pull out easily....then its just a matter of twist
pulling the bulb assembly off.
post Feb 7, 2003 - 9:11 PM
GTS_Bun
Joined Oct 21, '02
From Toronto, Canada
yup, blue reverse lights & license plate lights are illegal. Just keep this in mind.
Lo-Fi Version Time is now: November 27th, 2024 - 11:46 PM
