Installing a Fuel Pressure Regulator..., HOW??? |
Mar 26, 2004 - 11:28 PM |
Enthusiast Joined Feb 20, '04 From Washington Currently Offline Reputation: 0 (0%) |
Thanks 'mikedodson' for the equipment!! The only thing..... How do I install this?? I don't have any tubes, all the hard ware though. Does anyone know how to intall this??
Mar 27, 2004 - 3:41 AM |
Enthusiast Joined Jan 22, '04 From bellingham, WA Currently Offline Reputation: 0 (0%) |
do you have an adapter for the old regulator or no? if not i can tell you how to get around the stock regulator & how to install it.... i have one
**edit also, is it a rising rate adjustable fpr? This post has been edited by toyotaspeed_90: Mar 27, 2004 - 3:41 AM |
Mar 27, 2004 - 9:21 AM |
Enthusiast Joined Sep 9, '02 From Scranton, Pa Currently Offline Reputation: 7 (100%) |
keep the stock regulator there.. splice into the fuel line after it. it just T's in... ill explain it more in my how to. see my profile, u might be able to see some pictures to get a better idea.
Mar 27, 2004 - 8:30 PM |
why would you run the stock one w/o modifying it? at that point, you can't adjust the pressure any higher than the spring in the stock one will allow....... on the ST (4/7a-fe) the stock regulator sits on the fuel rail.... so you have to go through it unless you have an adapter (i went through it, but modified the stock one so that it can't regulate the pressure) |
Mar 27, 2004 - 9:45 PM |
Enthusiast Joined Sep 30, '02 From san diego Currently Offline Reputation: 0 (0%) |
You might try taking it to a local performance shop and see if they will tell you what you need. You only need a t-fitting and a few lines.
Mar 28, 2004 - 12:13 AM |
you can get around the stock one & i know how..... if you let me know if you need to know how i'll tell ya....lol
Lo-Fi Version | Time is now: November 27th, 2024 - 10:12 PM |
