Enthusiast ![]() ![]() ![]() Joined Apr 4, '04 From VA, USA Currently Offline Reputation: 0 (0%) ![]() |
DISCLAIMER: This wiring information is being provided on an "as is" basis, without any representation or Warranty. Is is your responsibility to Verify the wires by testing them
With that said....Lets get goin FYI: You will not need all the wires that I post, read your instructions ADMIN: please sticky this This post has been edited by Pali_playa: Apr 5, 2004 - 1:06 PM |
1994 Toyota Celica
Item Wire Color Polarity Wire Location 12V White- Brown/Red + Ignition Harness Starter Black/White + Ignition Harness Ignition Black/Orange + Ignition Harness Second Ignition Blue/Red + Ignition Harness Accessory Gray + Ignition Harness Power Lock Blue/Back - Lock Module right of column Power Unlock Blue and Green *1 - Lock Module right of column Parking Lights + Dk. Green At Dimmer Parking Lights - Lt. Green Steering Column Headlights Red/Black - Steering Column Door Trigger Red/White - Drivers Kick Panel *2 Trunk/Hatch Pin Red/Green - Drivers Kick Panel *2 Tachometer Gray Check Connector Brake Wire Green/White + Driver Kick Panel Horn Trigger Green - Steering Column LF Window up/down Green - Red Drivers Door Switch RF Window up/down Grn/Wht - Red/Blu Driver Kick Panel LR Window up/down RR Window up/down *1 Use both wires and diode isolate each. *2 Door and trunk trigger looped out of main harness heading towards rear of car, almost directly below door hinge wrapped in beige tape This post has been edited by Pali_playa: Apr 5, 2004 - 12:58 PM |
1995 Celica
Item Wire Color Polarity Wire Location 12V White- Black/Red + Ignition Harness Starter Black/White + Ignition Harness Ignition Black/Orange + Ignition Harness Second Ignition Blue/Red + Ignition Harness Accessory Gray + Ignition Harness Power Lock Blue/Back - Lock Module right of column Power Unlock Blue and Green *1 - Lock Module right of column Parking Lights + Dk. Green At Dimmer Parking Lights - Lt. Green Steering Column Headlights Red/Black - Steering Column Door Trigger Red/White - Drivers Kick Panel *2 Trunk/Hatch Pin Red/Green - Drivers Kick Panel *2 Tachometer Gray Check Connector Brake Wire Green/White + Driver Kick Panel Horn Trigger Green - Steering Column LF Window up/down Green - Red Drivers Door Switch RF Window up/down Grn/Wht - Red/Blu Driver Kick Panel LR Window up/down Grn/Wht - Red/Wht LR window switch RR Window up/down Green - Red RR window switch *1 Use both wires and diode isolate each. *2 Door and trunk trigger looped out of main harness heading towards rear of car, almost directly below door hinge wrapped in beige tape |
1996-1999 Toyota Celica
Item Wire Color Polarity Wire Location 12V White- Black/Red + Ignition Harness Starter Black/White + Ignition Harness Ignition Black/Orange + Ignition Harness Second Ignition Blue/Red + Ignition Harness Accessory Gray + Ignition Harness Power Lock Blue/Back - Lock Module right of column Power Unlock Blue and Green *2 - Lock Module right of column Parking Lights + Dk. Green At Dimmer Parking Lights - Lt. Green Steering Column Headlights Red/Black - Steering Column Door Trigger Red/White - Drivers Kick Panel *3 Trunk/Hatch Pin Red/Green - Drivers Kick Panel *3 Tachometer Gray Check Connector *1 Brake Wire Green/White + Driver Kick Panel Horn Trigger Green - Steering Column LF Window up/down Green - Red Drivers Door Switch RF Window up/down Grn/Wht - Red/Blu Driver Kick Panel LR Window up/down Grn/Wht - Red/Wht LR window switch RR Window up/down Green - Red RR window switch *1 On the 2.2 motor go to the ignitor on the rear drivers side of the engine compartment *2 Use both wires and diode isolate each. *3 Door and trunk trigger looped out of main harness heading towards rear of car, almost directly below door hinge wrapped in beige tape |
![]() Enthusiast ![]() ![]() ![]() Joined Dec 27, '02 From Sleep in Warren chill in clinton twp, works/school in detroit Currently Offline Reputation: 1 (100%) ![]() |
![]() ![]() ![]() sticky this -------------------- ![]() |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 19, '04 From Scottsdale, Az Currently Offline Reputation: 2 (100%) ![]() |
awesome. I can put in the viper alarm this weekend!
Enthusiast ![]() ![]() ![]() Joined Nov 18, '02 From Texas Currently Offline Reputation: 0 (0%) ![]() |
I've got a wire diagram of the gauge wires also in case anyone is wanting to make a custom gauge cluster (like I hope to do this summer). You can use the diagram to keep all the warning lights, blinkers, ets. If anyone needs it just let me know and I'll scan it and send it to you.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 10, '04 From Shoreline, WA Currently Offline Reputation: 4 (100%) ![]() |
note for those replacing a stock alarm in a 94 gt:
Its under the seat, and the harness that its connected to needs to be fixed in order to install a new alarm, and its easy. just unplug it, and cut off the plug, then look at all the wires, and connect the ones that are the same color, white/black with white/black etc. the old alarm uses a braker kinda thing to shut off surton things when the alarm gose off. this allows you to wire up a new one under the dash using the above listed wires rather then putting a new one under the seat. note: the colors do not match up, the ones listed above are correct but not the same as the ones under the seat, and there is no diagram for the ones under the seat. -------------------- ![]() |
Enthusiast ![]() ![]() Joined Jun 27, '04 From ohio Currently Offline Reputation: 7 (100%) ![]() |
I am in need of help!!! I am looking for someone or a company that will splice a wiring loom from a 7asfe to a 3sgte 3g. if anyone knows where i can find this info please contact lance at lantz2121@yahoo.com thanks
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 22, '03 From NOVA Currently Offline Reputation: 16 (100%) ![]() |
does anybody know the wires for the power mirrors?!? 96'
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 27, '04 Currently Offline Reputation: 14 (100%) ![]() |
I just installed a Viper Alarm and I wanted to thank you all on here for the information. I was able to read about wiring diagrams, how to's and images that helped me and my dad figure it all out.
Thank You! Special thanks to Coomer and Pali_playa for the wire listings and instructions. This post has been edited by Jaws4God: Feb 11, 2005 - 9:57 PM -------------------- ~Daniel~ No Longer Celica Owner.. moved on to a 03 WRX-EJ207
Enthusiast Joined May 10, '04 From Australia Currently Offline Reputation: 0 (0%) ![]() |
QUOTE(Jaws4God @ Feb 6, 2005 - 5:05 AM) I just installed a Viper Alarm and I wanted to thank you all on here for the information. I was able to read about wiring diagrams, how to's and images that helped me and my dad figure it all out. Thank You! Special thanks to Coomer and Pali_playa for the wire listings and instructions. [right][snapback]242549[/snapback][/right] would it be OK for you to forward that wiring diagrams to me? me and a friend of my would be trying to install a new alarm system in my 98 G6. This would be our first Attempt and any help would be greatly appreciated. my e-mail is "lord_of_anime@yahoo.com" |
![]() Enthusiast ![]() Joined Apr 7, '06 From Fontana, CA Currently Offline Reputation: 0 (0%) ![]() |
does anyone know where the tachometer wire is located on a 95 ST?
Enthusiast ![]() ![]() Joined Aug 22, '07 From Burnaby, British Columbia, Canada Currently Offline Reputation: 8 (100%) ![]() |
I was wondering if this information is relevant to GT-4's?
If not, does anyone have information on wiring for a 1994 GT-4? -------------------- |
![]() Enthusiast ![]() ![]() ![]() Joined Nov 18, '10 From montreal Currently Offline Reputation: 0 (0%) ![]() |
i know its old but here the info , all wiring diagram for celica gt-four 3th gen
http://gtfour.supras.org.nz/diagrams.htm enjoy |
![]() Enthusiast ![]() ![]() Joined May 9, '09 From Brisbane, Australia Currently Offline Reputation: 0 (0%) ![]() |
note for those replacing a stock alarm in a 94 gt: Its under the seat, and the harness that its connected to needs to be fixed in order to install a new alarm, and its easy. just unplug it, and cut off the plug, then look at all the wires, and connect the ones that are the same color, white/black with white/black etc. the old alarm uses a braker kinda thing to shut off surton things when the alarm gose off. this allows you to wire up a new one under the dash using the above listed wires rather then putting a new one under the seat. note: the colors do not match up, the ones listed above are correct but not the same as the ones under the seat, and there is no diagram for the ones under the seat. Eight years since this original post, has anyone managed to come across a wiring diagram for a 94 with the under seat alarm? -------------------- |
![]() Enthusiast ![]() ![]() Joined Apr 24, '13 From Tomball, TX Currently Offline Reputation: 3 (100%) ![]() |
Necro bump.
Does anyone know where the alarm brain is in a '96 convertible? It's not under the seat and i dont want to go tearing through the dash if i don't have to. -------------------- "As a professor of science, I assure you we did, in fact, evolve from filthy monkey-men." -Prof. Farnsworth
Enthusiast Joined Jul 29, '15 From Utah Currently Offline Reputation: 0 (0%) ![]() |
Does anyone know how to trouble shoot specific wiring problems??
Necro bump. Does anyone know where the alarm brain is in a '96 convertible? It's not under the seat and i dont want to go tearing through the dash if i don't have to. I just took my drivers side dash out under the steering wheel because I saw some cut wires just dangling, they were aftermarket connections that were spliced halfass into the original . I also noticed a lot of piggy back connectors up near the fuse block and since my car has no alarm on it I am gonna say that the alarm once was housed in that area directly under the steering wheel, theres lots of room for it. |
Lo-Fi Version | Time is now: February 17th, 2025 - 6:53 PM |
