> Clicking noise from front drivers side, any ideas what it could be?
post Apr 7, 2004 - 5:45 PM
veilside
Joined Sep 28, '03
From UK
Any ideas what i could be??? getting very annoying, happens at lowspeeds especially when turning left confused.gif frown.gif
post Apr 7, 2004 - 5:49 PM
mikew04
Joined Feb 19, '04
From austin tx
CV's?
post Apr 7, 2004 - 6:42 PM
fastgt
Joined Feb 13, '03
From California
more than likely its the axel or cv if youd like, you may also want to check the wheel hub bearing
This post has been edited by fastgt: Apr 7, 2004 - 6:59 PM
2011 Spice Orange Mini Cooper
2011 Alpine White BMW E92 M3
gone but not forgotten
2008 Space Grey BMW Z4 ///M
fastgt
Joined Feb 13, '03
From California
oooops sorry
This post has been edited by fastgt: Apr 7, 2004 - 6:42 PM
post Apr 7, 2004 - 7:34 PM
veilside
Joined Sep 28, '03
From UK
any ideas how i can check if its the cv joint or the axle myself???? no time to take it to mechnic now since its Bank holiday in the uk frown.gif
post Apr 7, 2004 - 7:38 PM
Junior
Joined May 5, '03
From Toronto
its the axle, i'm almost sure of it. I'm having the same problem. You can drive on it still and you should be fine. Take it to the mechanic when you get a chance.
post Apr 8, 2004 - 2:42 PM
veilside
Joined Sep 28, '03
From UK
post Apr 8, 2004 - 3:44 PM
aaronc222
Joined Sep 22, '02
From Detroit
The passenger side CV joint is $59.99(USD) from AutoZone. I'd imagine that the driver side is about the same. I haven't changed mine yet, just got some prices because I need to do it soon(same low speed clicking while turning).
post Apr 8, 2004 - 4:59 PM
Junior
Joined May 5, '03
From Toronto
I haven't changed mine as yet because i got a winter beater, but a rebuilt axle is 85 cdn plus core. Make sure you let the shop know if you got abs or not, it makes a difference in the axle.
post Apr 8, 2004 - 6:19 PM
veilside
Joined Sep 28, '03
From UK
sounds like a pretty expensive job *sigh*
post Apr 8, 2004 - 6:36 PM
fastgt
Joined Feb 13, '03
From California
its not that hard , id give you a walkthrough but youd have to talk to me on aim
post Apr 9, 2004 - 11:00 AM
wind
Joined Nov 4, '03
From Vancouver, Canada!
drivers side is more expensive last time i asked toyota
post Apr 9, 2004 - 7:20 PM
veilside
Joined Sep 28, '03
From UK
fastgt - i dont have a aim account, frown.gif , im not even sure what the problem is yet, think i take it to my mechnic and have him take a look at it frown.gif the clicking is getting worse , happens more when the car is cold, what does this indicate??
post Apr 9, 2004 - 7:44 PM
kevstir
Joined Jul 5, '03
From Scotland , Uk
Hey veilside if its the cv joint look under the front of the car and look behind the drivers wheel u will see a rubber gator at the end of the driveshaft if u can see its split and chucking grease out all over the place then i would say it the cv joint , also does it only do it when turning?? if so then its the cv joint , have u looked at the tyre there could be a nial in it (i had that prob)..hope u get it sorted m8
Kevstir
post Apr 9, 2004 - 7:56 PM
veilside
Joined Sep 28, '03
From UK
cheers kev u pisshead biggrin.gif dont think it can be a nail since the clicking sounds a lot more than a nail clciking against the road
post Apr 10, 2004 - 2:09 AM
fastgt
Joined Feb 13, '03
From California
looks heres what u do, take off your tire, check the inner and outta boots if either one of them is ripped u might be able to get away just changing the boots, 30 bucks for a kit at toyota, but if its way bad then u must change the entire cv, im not saying its for sure but i dont see what else it could be than the cv, unless its the wheel bearing as i stated earlier
post Apr 10, 2004 - 8:29 AM
veilside
Joined Sep 28, '03
From UK
any ideas how to check wheel bearings? got rough idea , sth along the lines of turning the wheel to listn put for grinds etc. am i along the right lines biggrin.gif
post Apr 10, 2004 - 8:44 AM
97GTinKC
From KC
Go here, check the troubleshooting link
http://www.raxles.com/fundamen.htm
and if I need to do any in the future, I will buy a NEW joint and put it on my axle, the rebuilt axle assemblys dont last (in my experience). Or a NEW assembly from Raxles or somebody.
This post has been edited by 97GTinKC: Apr 10, 2004 - 8:51 AM
post Apr 10, 2004 - 8:47 AM
97GTinKC
From KC
,,,And watch those rebuilt axles, all they seem to do on the cheap ones is wash them out, maybe drop new ball bearings in (on the worn races), new boots and resell them, put 3 in my Mazda in 18 months, yes they are warrantied, but its a pain in the ass to keep changing them.
post Apr 10, 2004 - 7:30 PM
veilside
Joined Sep 28, '03
From UK
cheers 97GTinKC biggrin.gif driving the car today and noticed the clicking occurs more frequent when cold with the car jus started, but when the car is all warmed up the clicks are less frequent
Lo-Fi Version Time is now: November 27th, 2024 - 6:01 PM
