Rolling my fenders, need some advice |
May 3, 2004 - 9:21 PM |
Enthusiast Joined Aug 30, '02 From North Carolina Currently Offline Reputation: 0 (0%) |
With my new 18's on, my wheel spacers, and my coil-overs, when i hit a bump my tires rub the lip on my rear fenders. I want to role that little lip, but don't want to bend the fender. How can i do this? i don't want to get rid of the spacers, or raise the car.
adam -------------------- MISS THE CELI, BUT...
May 3, 2004 - 10:19 PM |
Enthusiast Joined Jun 21, '03 From FRANKFORT,KENTUCKY Currently Offline Reputation: 0 (0%) |
Jack the car up and use a baseball bat. Roll the bat with a little pressure,too much pressure will be bad.
This post has been edited by 95STHATCH: May 3, 2004 - 10:21 PM |
May 4, 2004 - 12:24 AM |
Enthusiast Joined Mar 19, '04 From Scottsdale, Az Currently Offline Reputation: 2 (100%) |
When I get back to work, I got a article there on how to do it. I will scan it and send it to you. I believe it also said to heat up the fender with a heat gun so the paint does not chip.
May 4, 2004 - 8:56 AM |
That would be great. thanks. adam -------------------- MISS THE CELI, BUT...
May 4, 2004 - 9:07 AM |
Enthusiast Joined May 5, '03 From Toronto Currently Offline Reputation: 3 (100%) |
I noticed that in your profile you didn't list any upgrades to your struts. I would suggest getting a some stiffers shocks like koni's. Also the spring rate on the drop zone coilovers is pretty low. You'll bounce a lot, the stiffer suspension will help a lot. To roll your fenders you need to make some cuts every inch on the inside of the fender. Then take a torch and heat it up, do heat it up till its red, just enough so it'll bend easier with out the paint peeling. While the fender is hot, bang it out with a rubber mallet. After you're done, i'd tape up the car and spray the inside of the fender with paint to prevent rust from all the cuts you made.
May 4, 2004 - 10:25 PM |
Enthusiast Joined Oct 9, '02 From Longmont, CO Currently Offline Reputation: 1 (100%) |
I just read something earlier today on that. It was about using a baseball bat. I'll see if I can find the article.
May 5, 2004 - 9:32 AM |
Heres the LINK
May 5, 2004 - 10:04 AM |
in that last shot, the fender looks a little warped.
May 8, 2004 - 3:54 PM |
I just took a saw and made little cuts in the inside of the fender every couple of inches for about 18-20 inches. Then i heated the fender up with a hair dryer and beat it back with a rubber hammer then i of course primed and re-painted it. Looks good and i don't rub anymore.
May 8, 2004 - 4:03 PM |
Enthusiast Joined Jun 26, '03 From Wisconsin Currently Offline Reputation: 0 (0%) |
holy.... i just laughed so hard because like out of nowhere comes his special fender rolling too -------------------- i am awesome
Lo-Fi Version | Time is now: December 12th, 2024 - 1:03 PM |
