> Sub Installation Help, No idea wtf im doing wrong!
post Feb 13, 2003 - 7:37 PM
TRDracerGT
Joined Sep 13, '02
From Maryland
http://celica.net/cgi-bin/ultimatebb.cgi?u...ic;f=3;t=001473
post Feb 13, 2003 - 7:41 PM
DavezXTC
Joined Feb 3, '03
From Pensacola Florida
one thing you can do is hook up a speaker that you already know is working to your amp outputs just to see if your getting anything to the speakers in the first place smile.gif
post Feb 13, 2003 - 7:52 PM
TRDracerGT
Joined Sep 13, '02
From Maryland
okay anything else i can do? Thanks man
post Feb 13, 2003 - 8:09 PM
Guest_Jason_*
Turn your Subs on - on your deck. My Pioneer deck had a function you need to enable to activate Subs.
post Feb 13, 2003 - 10:24 PM
TRDracerGT
Joined Sep 13, '02
From Maryland
I tryed messing with the deck but i cant find anybutton on there that turns them on.. I have the JVC KD-SH909R model if that helps. When i looked the cd player up on line it says it includes a subwoofer line out??? Not sure what that means.. Thanks again for the help. People here at 6gc.net are the best!
http://www.jvcmobile.co.uk/html/kd-sh707r.html
Tyler
post Feb 13, 2003 - 11:38 PM
94blackst
Joined Jan 20, '03
From Denver, co
the stereo has rca outputs on the back, thats usually what a sub line out means. Did you hook your rca lines to them?
post Feb 13, 2003 - 11:54 PM
slowceli
Joined Oct 31, '02
From grants pass oregon
usally when a deck has a sub line out there is also a seperate control for the subs. if there is it could be turned all the way down witch would mute the subs
post Feb 14, 2003 - 12:28 AM
pleue
Joined Nov 12, '02
From bayarea
You ****in noob! oh wait we're not on celica.net hahaha wink.gif So if the amp is working then your power, ground and amp led is hooked up correctly. lemme see. again, check on your deck to make sure the sub volume is up it should be in the same section as bass, treb, fade, balance, etc. Um, make sure your rca plug is hooked up to the sub preamp on the back of your deck. Take the subs out of the box and directly test each of them to the amp by hooking up wires. how many channels is your amp cuz if its more than one you should test subs on both channels as well as bridged. You could also try another rca cable or try plugging it into the front or rear preamp input on the back. Make sure youre not plugged into the aux input. that's about all i can think of. good luck.
post Feb 14, 2003 - 1:20 PM
TRDracerGT
Joined Sep 13, '02
From Maryland
Hey all thanks for the replies.. As soon as i get home i am going to try your suggestions and see if it works. Ill let you know how it goes!
Tyler
post Feb 15, 2003 - 11:17 AM
TRDracerGT
Joined Sep 13, '02
From Maryland
Alright I think I figured out the problem.. It has something to do with the ground wire. When i touch a screw driver against metal it grounds it and the subs work. I tryed grounding the wire then to a screw in the bottom right hand corner right above the right rear wheel but for some reason that dosnt work. If i hold screw driver against the screw and then to the side where it is metal than it works. hmmm?? If you guys have any pictures of your wriring and where u grounded your wires it would be much appreciated. Sorry if this thread keeps coming up.
Tyler
post Feb 15, 2003 - 9:11 PM
OCU_Celi
Joined Aug 30, '02
From Rolla, Misery (Missouri)
did you scratch away all the paint from the spot you're grounding? that may be a problem. i grounded min in the strut tower screw. oh course my amp sits only a foot away and it's a straight shot. i'll take a pic and post it when i get home tomorrow.
Nathan
post Feb 16, 2003 - 12:27 AM
FallenHero
Joined Dec 26, '02
From Alabama
Ground it to one of the bolts on your seat.
post Feb 16, 2003 - 4:01 AM
94celicaguy
Joined Nov 11, '02
if you look between your back seats underneath the bit of seat fabric at the back, you will see three bolts going into the body. these three bolts are connected to a thing that holds the seats in place. undo one of those bolts and ground your wire right there. i am telling you, that is the best place on the car to ground it.
post Feb 17, 2003 - 1:28 AM
Celica95
Joined Sep 4, '02
From Meridian, MS
Thats where mine is grounded at, Ive had no problems.
Lo-Fi Version Time is now: November 24th, 2024 - 12:51 PM
