> TOO BOUNCY!!, help!
post May 16, 2004 - 8:57 PM
94silverst
Joined Feb 20, '04
From Washington
I have coilovers on my Celica (Dropzone). I like the handeling, like the look, I know what to do about the poping noise, BUT IS there anything I can do about the ride being so bouncy?? Anyone have input?? Thanks! wink.gif
post May 16, 2004 - 10:12 PM
koni yellow struts
post May 16, 2004 - 10:40 PM
macavely
Joined Nov 4, '02
check yout sturts they might be shot
post May 16, 2004 - 11:58 PM
Junior
Joined May 5, '03
From Toronto
new struts and better coilovers.
post May 17, 2004 - 12:43 AM
creis
Joined Jan 10, '04
From Shoreline, WA
there is not much you can do about it, sept get new springs. i dont know much about dropzone, but i have Vaos XR2's there very good, and very cheep.
post May 17, 2004 - 2:54 AM
Hanyo
Joined Aug 16, '03
From Bay area
what makes a car bouncy?
i know cut spring will make a car bouncy, but what actually causes it?
post May 17, 2004 - 6:53 AM
CelicaQT
Joined Sep 29, '02
From Sterling Heights, Michigan
QUOTE (Hanyo @ May 17, 2004 - 3:54 AM)
bad springs or bad shocks.
post May 17, 2004 - 7:19 AM
Uppitycracker
Joined Jul 12, '03
From Chatham, Ont
Well stock struts aren't meant to handle the spring rates of lowering springs/coil overs. So while had the coilovers put in you should have had struts put in along with them.
post May 17, 2004 - 10:50 AM
Junior
Joined May 5, '03
From Toronto
Dropzone coilovers are cheap. You get what you pay for, and in this case you got cheap coilovers with a low spring rate. You will get a lot of bounce.
post May 17, 2004 - 11:25 AM
94silverst
Joined Feb 20, '04
From Washington
Thanks for all the replys!! So, If I get better coilover springs they will ride smoother?? I can't stand bouncing so much, but the bouncing is comming from the stiffness of the spring I think is that correct?? Its not bouncy be cause the spring is soft, I can literally feel every bump i hit! Will new coil springs do the job? confused.gif
post May 17, 2004 - 12:04 PM
98celica3
Joined Aug 30, '02
From North Carolina
QUOTE (94silverst @ May 17, 2004 - 9:25 AM)
if you get GC's i think it will ride alot smoother. I have the dropzones as well and they are bouncy, good thing i don't drive my car everyday. new struts will make it a little smoother, but because of the stiff spring rate of the coil-over springs it will still bounce alot. any lowering springs will be an improvement in ride quality.
adam
MISS THE CELI, BUT...
post May 17, 2004 - 12:14 PM
CelicaQT
Joined Sep 29, '02
Just a word of advice, I've had the GC's on my stock shocks for more than a yr and I just took them off this past saturday (May 15th) and the sleeve seized itself onto the shock housing. When I looked at the other side there was a crack about 1" long going from the very bottom of the sleeve to the top.
If I were going to get new Coilovers, I'd definitely go with something that's a complete assembly. I wouldn't risk anyones safety with them splitting the way mine did. frown.gif
Just a heads up.
post May 17, 2004 - 10:18 PM
Hanyo
Joined Aug 16, '03
From Bay area
QUOTE (94silverst @ May 17, 2004 - 4:25 PM)
i would think soft springs will make a smoother ride.
But i'm a noob at suspention..
post May 17, 2004 - 11:03 PM
Uppitycracker
Joined Jul 12, '03
From Chatham, Ont
Theres a difference between bumpy and bouncy!!
If its bumpy its because they are stiff because you probably have it lowered significantly, correct? Which means you will feel BUMPS in the road alot more.
Bouncy is literally bouncing, like up and down up and down, that doesnt look to be the case.
post May 24, 2004 - 10:31 AM
amysmojo
Joined Mar 18, '04
QUOTE (creis @ May 17, 2004 - 5:43 AM)
Nice creis!! I have the exact same ones. I like them too, but I think I need new struts because the ride is pretty hard (bumpy) Here is the web site for more info: VAOS biggrin.gif
post May 24, 2004 - 5:19 PM
TRD6GC
Joined Nov 17, '03
I have a good idea, it helped with me a lot so it should for you. When you take your stcok suspension apart there are hard rubber pieces on the strut called "bumper stops". I would highly encourage you to cut them in half and put it back onto the stru with your aftermarket coil-overs. Since im so low i use to bottom out my actual strut until i put these in and, plus the rides smoother. So good luck.
post May 25, 2004 - 4:51 AM
xeril
Joined May 24, '04
From state of northern virginia
hmm, i am terrible at explaining ****, but here it goes:
your struts are meant to handle oem springs. they weren't designed for springs or coilovers, which tend to kick up the spring rates a bunch. the struts are capable of properly dampening the lower spring rate springs, but once you bump the spring rates up, the struts cant handle them anymore. basically, be sure to pair up your springs with the proper struts for the application. if you are looking for more aggressive springrates, don't skimp on the struts. bleh, everyone just buy the koni's and be happy with them smile.gif if you end up blowing them (which is pretty hard to do), you can send them away to a company to get them rebuilt and able to take 500-1500 custom spring rates! why you'd want that for daily driver...i dunno.
Lo-Fi Version Time is now: January 12th, 2025 - 4:59 AM
