> GT-4 front end part #'s, sticky?
post Jun 11, 2004 - 9:41 AM
ok all heres a COMPLETE list of all the GT-4 front end part #'s, descriptions, what you'll need, and where to get it. wink.gif
the list will include some "optional" parts, so that those of you who want every little part ( like i did) can get them.
where i could, i included prices, these are prices that i got from my local dealer, which in most cases you can get a 15% discount or more off that price.
BUMPER PARTS
Cover, front bumper 52521-20200 $223.27 this is the bumper
Absorber,front bumper energy 52611-20150 $62.76 this is the foam that goes behind the bumper
Seal, hood to front end panel 53395-20020 $19.92 this is the rubber seal where the hood and bumper meet
retainer, front bumper upper center 52521-20200 $25.44 this is the metal thing that holds the rubber in place
grille sub-assy, rad., center 53101-20500 $46.29 this is the upper grille
grille, radiator, lower 53111-20750 $125.08 this is the lower grille
bezel, grille, lower RH 53112-20240 this is the bezel for the lower grill WITHOUT fogs
bezel, grille lower LH 53113-20180 bezel for lower grill WITHOUT fogs
front turn sig. RH 81510-20750
front turn sig. LH 81520-20750
FOGS & OTHER OPTIONAL PARTS
fog lamp RH 81210-20370
fog lamp LH 81220-20360
bezel grille lower RH 53112-20230 RH fog light bezel
bezel grille lower LH 53113-20180 LH fog light bezel
latch, hood LHD 53510-20510 this is the LHD GT-4 hood latch, without it, you'll have to lengthen your stock latch by about 1/2 inch.
bracket upper grille#1 53115-20070 $13.95 1 of 2 brackets which hold in the upper grille
bracket upper grille #2 53118-20070 $15.46 2nd bracket for upper grille
you can also get the reinforcment bar(your "crash-bar" or 5MPH bumper) and frame brackets, but theyre not nessicary, and the frame brackets required to use them are $180 EA from toyota. so just about everyone dont get it, they just cut down theyre crash bar with a sawzall.
HOOD PARTS
Hood sub-assy. 53301-20500 $444.22 hood
plate assy, hood bulge 76190-20010 $ 42.95 middle hood vent
bulge assy, hood 76180-20010-AO hood bulge (the -AO after the pt# is a paint code, if you know your code insert it there.)
ornament sub assy, hood RH 75033-20030-AO RH rear vent
ornament sub-assy, hood LH 75034-20030-AO LH rear vent
guide,air to cowl 76191-20901 hood spoiler
any part #'s without prices are all parts you can get from your local dealer.
for the other stuff i recommend www.toyotaworld.com you can call them and they can get any or all of the parts you need.
manny
post Jun 11, 2004 - 10:52 AM
http://www.6gc.net/forums/index.php?showtopic=1481
Way to look up.
post Jun 11, 2004 - 1:31 PM
post Jun 12, 2004 - 5:02 PM
Outsider
From Kelowna, BC
I added the paint codes to the post already.
1994 GT-S (BEAMS) swap complete
post Jun 13, 2004 - 8:03 AM
you guys arnt reading the post...theres part #'s missing from the lists that are stickied..brackets, fogs, bezels.. wink.gif i just wanna try and get it all in one spot, with where to get the stuff info, to try and clear up some of the confusion about it..
manny
Lo-Fi Version Time is now: February 22nd, 2025 - 1:48 AM
