can someone help me figure out what bolts go where in the crossmember? i got a bunch of bolts in a bag, but im not sure what ones i removed from what locations.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Nov 4, '02 From Hecho en la Republica Dominicana/Living in NJ Currently Offline Reputation: 0 (0%) ![]() |
well start with the ones that fit.. not sure which if the have a mark on them or not..
![]() Enthusiast ![]() ![]() ![]() Joined Apr 10, '03 From South Central Los Angeles Currently Offline Reputation: 0 (0%) ![]() |
for the front of the crossmember, there should be only 2 bolts. I think they're 12mm and about 1 inch long.
For the rear of the crossmember, there should be 3 that hold it with the motor mount. I think it should be (1) 14mm bolt about 1.5 inch long and (2) 14mm nuts. I hope that makes sense and helps. |
![]() Moderator ![]() ![]() ![]() ![]() ![]() Joined Apr 17, '03 From Rockland NY Currently Offline Reputation: 15 (100%) ![]() |
guess we should have labled them ......
The longest one goes in the middle of the three under the door hinges . the two 12 millimeter bolts are for the front under the radiator. you should also have those two that were holding the exhaust pipe. (14mm) the 17 or 18 mm where the ones the bolted in horizontally. get on the ground and look towards where the sway bar links would be and you should see the hole or maybe below that to the left or to the right depending which side ur looking at. do any of those manuals tell you ? Thats what I remember DEF -------------------- ![]() I will return one day. |
Lo-Fi Version | Time is now: February 22nd, 2025 - 6:18 AM |
