> Ticking from the engine, Timing belt?
post Jun 25, 2004 - 11:46 PM
YellowTwo
Joined Jul 25, '03
From Santa Barbara, CA
I'm hearing ticking sounds coming from my engine, and the faster I go the faster it ticks. (No it's not a bomb) lol
I just got the timing belt replaced and the guy said if I don't get the kit, which was $200 more, it might make squeaking noises or something. I decided I didn't wanna pay an extra $200 just for that, so I just got the belt itself. But could that be the cause of the ticking?
post Jun 26, 2004 - 12:22 AM
95STHATCH
Joined Jun 21, '03
From FRANKFORT,KENTUCKY
It could be your lifters hitting. Start your car and listen for noises coming out under the valve cover. I'm pretty sure that it's not the timing belt,I've never heard of one ticking before. Is your timing off any? If your timing is off it could cause internal parts to hit a little or alot but from what you are describing it sounds like your lifters.
post Jun 26, 2004 - 8:06 AM
gas65
Joined Nov 6, '03
From Campbellsville, Ky.
Check your oil level also.
post Jun 26, 2004 - 12:55 PM
S_C_M
Joined Mar 2, '04
From Louisiana, USA
What gas65 said; check your oil level. If it is normal, you may have valve clearance problems, which can be checked by feeler gauges. Our cars do not have lifters, the cams operate shimmed buckets that directly actuate the valves.
post Jun 26, 2004 - 3:05 PM
Junior
Joined May 5, '03
From Toronto
Its a valve tick. Notorious in 4 bangers.
post Jun 26, 2004 - 3:17 PM
shid
Joined Jan 8, '04
From LA
I come back to my car after half an hour of it sitting there and it's still "settling" lol
post Jun 26, 2004 - 3:18 PM
drdos
Joined Aug 19, '03
From Buffalo,NY
QUOTE (Junior @ Jun 26, 2004 - 8:05 PM)
yep so do i.
post Jun 28, 2004 - 11:14 PM
YellowTwo
Joined Jul 25, '03
QUOTE (Junior @ Jun 26, 2004 - 1:05 PM)
What does that mean? Does it need to be fixed or is it pretty harmless?
Lo-Fi Version Time is now: February 23rd, 2025 - 8:18 AM
