> eibach prokit question, install question
post Jul 7, 2004 - 6:32 PM
Jdog1385
Joined Apr 14, '03
From Long Island, N.Y.
Quick question... my mechanic is putting in my prokit for me and he is having trouble with the front springs. when he turns the wheels, the front springs are shifting and they are not set on the struts. i have stock struts and all i modified was the springs. do i need to buy anything else?
justin
post Jul 7, 2004 - 6:34 PM
Andason
Joined Jun 26, '03
From Wisconsin
line the springs in the top and bottom of the holder correctly
i am awesome
post Jul 7, 2004 - 6:37 PM
QUOTE (Andason @ Jul 7, 2004 - 4:34 PM)
Yeah, they should lock into place once they're lined up so that the end of the spring stops on that little bump. You shouldn't need anything else. smile.gif
post Jul 7, 2004 - 6:46 PM
Jdog1385
Joined Apr 14, '03
yea, thanks guys. thats what i thought. i knew he wasn't putting them in right. he's out tongue.gif
This post has been edited by Jdog1385: Jul 7, 2004 - 6:48 PM
post Jul 7, 2004 - 10:46 PM
mr_dude
Joined Feb 16, '04
From San Diego
I think you're supposed to index the springs just away from the little bump.
Still, I would think (especially with stock struts) that the car's weight would hold the springs in place. You check the Pro-Kit part numbers to be sure?
post Jul 8, 2004 - 6:42 AM
Outsider
From Kelowna, BC
I had the same problem with mine when I put them in. I had to pull everything apart and seat them properly. I was a bit of a pain to do but the problem went away when seated. I still get squeeks out of them once in a while.
1994 GT-S (BEAMS) swap complete
post Jul 8, 2004 - 2:03 PM
Jdog1385
Joined Apr 14, '03
Thanks for the info. My mechanic is a perfectionist so he won't tolerate the springs moving around. hes going to rebuild the entire front struts and if it doesn't work im going to buy different springs. does the same thing happen with the sportlines?
post Jul 8, 2004 - 5:08 PM
Negative
Joined Apr 28, '04
From Houston, Texas
I had zero problems with the sportlines two weeks ago.
post Jul 9, 2004 - 5:28 PM
Jdog1385
Joined Apr 14, '03
yea, im going with koni struts and prokit springs
Lo-Fi Version Time is now: November 25th, 2024 - 7:52 AM
