Enthusiast ![]() ![]() ![]() Joined Apr 4, '04 From VA, USA Currently Offline Reputation: 0 (0%) ![]() |
just got my window control module and im ready to install. but i cannot seem to plan out how i am gonna get it from the door to the car. i can either go through the plug or drill a new hole. normally i would go through the plug, but the problem is, i gotta get 4 wires in+16GA wire for future system install. anyone have any bright ideas?
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 3, '04 From Hollywood, MD Currently Offline Reputation: 6 (100%) ![]() |
i suggest pulling the wire through with a coat hanger (going through the little booty where the other wires are run)
or you can take a screwdriver and pry the seal of the booty on each end leaving you open spots to run wires through, then so its not a sight for sore eyes wrap it all up in electrical tape when your done. |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 8, '04 From LA Currently Offline Reputation: 0 (0%) ![]() |
There's a post on this about a week back.. 2 pages long
![]() Enthusiast ![]() ![]() ![]() Joined Feb 16, '04 From San Diego Currently Offline Reputation: 0 (0%) ![]() |
I just did it for my locks, I wrapped the hot/ground wires together and they had enough stiffness to make it through.
Takes a few tries, just make sure you go from door to car. -------------------- ![]() |
![]() Enthusiast ![]() ![]() Joined Aug 29, '02 From Kelowna, BC Currently Offline Reputation: 0 (0%) ![]() |
When I wired in my new mirrors I had to run wires that were missing.(to control the folding motor)
I used a coat hanger with the wire taped to it to pull them through the door rubber plug, 90% of my install time was just running the wires. I was very happy with the final result as things look stock with no new holes or out of place wires. -------------------- ![]() 1994 GT-S (BEAMS) swap complete |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 20, '03 From Annapolis, Md Currently Offline Reputation: 5 (100%) ![]() |
yeah it takes a lil, I did it both for my windows, an locks.. if someone didnt already say, take out your speakers.. that will even help for more room to work with.
Lo-Fi Version | Time is now: February 25th, 2025 - 5:58 PM |
