2nd 3S-GTE and 3rd 3S-GTE, Are they same?? |
Aug 4, 2004 - 2:23 PM |
Enthusiast Joined Dec 21, '03 From Lynnwood, WA Currently Offline Reputation: 0 (0%) |
Hi, guys
I have a question that is about do all aftermarket stuffs can be used in both engine?? Such as cam grears, cam-shafts, and even ECU?? |
Aug 4, 2004 - 2:47 PM |
Not sure on the internal engine parts(I'd guess that they're not compatible though), but I know for a fact that the ECUs are different.
Aug 4, 2004 - 3:01 PM |
Enthusiast Joined Aug 19, '03 From Buffalo,NY Currently Offline Reputation: 0 (0%) |
internals are stronger in the 3rd gen
also has a bigger turbo larger fuel injectors and feul cut off at 15 psi i think? not 100% though. but thats what i know |
Aug 4, 2004 - 4:04 PM |
Enthusiast Joined Jun 11, '04 From Wake Forest, NC Currently Offline Reputation: 0 (0%) |
and the boast is set at 13psi compared to 10psi, its got a map sensor instead of AFM, new engine management, ct26 instead of ct20b, new ecu, larger o2 sensor, more agressive cams, revised internals and cooling, new intake manifold, lower compression, ss head gasket, 540cc compared to 430cc injectors, bigger bore on fuel rail, relocated feul pressure regulator, tvis eliminated, throttle body increased to 60mm, valve lift increased to 8.7, tempeture sensor in intake manifold, aluminum oil pan, larger exhaust elbow, better oil cooling.
i think thats it, i have like 4pages on the 3sgte engine and one of them is about the difference's between the 2nd and 3rd generation, i'll try to find a link if i can. |
Aug 4, 2004 - 7:45 PM |
Thx u guys' information.
But recently, I just found some JUN cam-shafts can be used in both 2nd and 3rd gen 3S-GTE, then I just think do all engine internal parts can be used together. |
Lo-Fi Version | Time is now: January 10th, 2025 - 5:56 PM |
