> Ignition PUSH BUTTON
post Aug 4, 2004 - 8:41 PM
does anyone know the wire color meanings of the wire that go to the ignition ....
cause i want to eliminate my key entirely when i get the push button so i need to know what each wire means so i can cut off the key
post Aug 4, 2004 - 8:51 PM
Pali_playa
Joined Apr 4, '04
From VA, USA
*cough* wiring digrams on stocky*cough*
post Aug 4, 2004 - 10:35 PM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
sweet were exactly do you live.. cause it only takes 10 secs to pop the lock... an no key.. humm, I could use a new ride..
post Aug 4, 2004 - 11:07 PM
rlan214
Joined Dec 27, '02
From Sleep in Warren chill in clinton twp, works/school in detroit
push start work with manual tranny right ?
just wondering cuz i heard there's a complication with manual tranny and auto start
post Aug 4, 2004 - 11:08 PM
Mynzeyes
From Franklin/Nashville, TN
ok. you still will need the key in the on position..there's really no way around that, other than if you wire up a switch...i had mine set up to where ONLY the button would start the car...so you had to turn the key, then hit the button...
the wire you need on the ignition cylinder is the black/white wire. then you'll need a constant 12v, then a 12v when "on", and a ground.
if you want it set up like i had mine, just cut the white/black wire, and run the end coming from the body harness to the starter button. just leave the end comin outta the plug hangin. smile.gif.
AIM==Mynzeyes
post Aug 4, 2004 - 11:09 PM
Mynzeyes
QUOTE (rlan214 @ Aug 4, 2004 - 11:07 PM)
it's different. the push button start is just like turning the key..you will just need to have the clutch pushed in, etc...
AIM==Mynzeyes
post Aug 5, 2004 - 9:06 AM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
You can by-pass the clutch, you can also by-pass the ignition.. well key start.. your goign to have to get some sort of acuator or somthing thats timed.. like hook it through a remote start or somthing, so you dont blow your starter.. I personally think its the stupidist thing you can do... an If ya do it, dont tell anyone
post Aug 6, 2004 - 5:49 PM
rlan214
Joined Dec 27, '02
QUOTE (Mynzeyes @ Aug 4, 2004 - 9:09 PM)
so its like an auto start but you need to push the button
does it also turn off the car when you step on the brakes or something
i guess I just need something to warm my car up for winter that is a lil bit faster and safer than leaving your keys in your car
post Aug 6, 2004 - 5:59 PM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
QUOTE (rlan214 @ Aug 6, 2004 - 10:49 PM)
Then just get a remote start... I have to set mine up.. or somthing like that.. wait .. I cant remember but a buddy said its hooked up, but somthing has to be done to get ti to work.. like the clutch is bypased.. anyone know??
post Aug 6, 2004 - 6:01 PM
turboinduction
Joined Feb 25, '04
From Wisconsin
Ignition Push Button is not Auto-Start
This is a feature that is found on the Viper and S2000 to name two. You put the key into the ignition, turn it to "on" not "start" and then hit the "Start" button normally put in the cig lighter. Your car will start as if you turned to key to "Start." Auto-Start is found on alarm systems and keyless entry. For a manual you'll need a clutch-bypass so the clutch doesn't have to be despressed to engage the ignition. This of course is dangerous if you leave you car in gear and dont set your e-brake. Automatics will be fine either way. The "start" button is an awesome add-on to any car and makes a great "talk piece" as the MaryKay ladies would say. I'd either put it in my cig lighter or the circle area at the top of the left vent of the steering wheel. If someone would like to do a full how-to I'd love to see something written up.
of course it'll go through Chris's 3-month waiting period before posted wink.gif j/k biggrin.gif.
This post has been edited by turboinduction: Aug 6, 2004 - 6:03 PM
post Aug 6, 2004 - 6:04 PM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
QUOTE (turboinduction @ Aug 6, 2004 - 11:01 PM)
not to be rude, or I may be mistaken, but I think he knows the dif.. I think hes looking for just a push start button, so you dont even need the key, like just have a remote for the alarm, an thats it..
post Aug 6, 2004 - 6:08 PM
turboinduction
Joined Feb 25, '04
From Wisconsin
From this it sounded like he didn't know the difference between the two. Now, an auto-start from a push button without keys is plain silly. Anyone can bust in and drive away. Maybe I mis-read.
post Aug 6, 2004 - 8:21 PM
rlan214
Joined Dec 27, '02
QUOTE (Digndoug @ Aug 6, 2004 - 4:04 PM)
yup
so you guys think i should just get an auto start and make sure I leave my car in neutral and ebrake ?
post Aug 6, 2004 - 11:36 PM
yea who knows what is goin on now.....what i was saying when i stared this post is...
1) i'm goin to install a push button start
2) eliminate the key
3) install kill switch for all electricty to where the key is supposed to go
4) secret....
5) REMOTE/AUTO start is VERY VERY different than what this subject is about
post Aug 7, 2004 - 8:10 AM
turboinduction
Joined Feb 25, '04
From Wisconsin
thus why I said my post - It seemed to go from Start button to remote start... hum. Either way - all good info. smile.gif
post Aug 7, 2004 - 12:57 PM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
what you could do, that would be pretty cool, to get ride of the key, is get a digital lock or somthing like that.. I know the new benz has somthing like that..
post Aug 7, 2004 - 2:22 PM
Pali_playa
Joined Apr 4, '04
From VA, USA
QUOTE (Digndoug @ Aug 7, 2004 - 1:57 PM)
can u say cha ching? that will cost a bundle, not to mention a very advanced install
post Aug 7, 2004 - 2:38 PM
turboinduction
Joined Feb 25, '04
From Wisconsin
post Aug 8, 2004 - 6:44 PM
haha, what are you goin to pad lock??, i actually figured it out i'll take the ignition out but leave it inside the dash with the key in it 24/7 in the start position (i can still access the key to take it out though) and i'll have a kill switch for the electricity to the ignition so its not always on...or sumthing of that nature i'm not sure what i'm goin to do as of now just tossing around ideas, thanks for the info
post Aug 8, 2004 - 8:18 PM
Pali_playa
Joined Apr 4, '04
From VA, USA
lol y dont you get a numeric keypad and hook it up to that, thatd be pimp, like in the transporter
EDIT: I found one! now i wanna do that
This post has been edited by Pali_playa: Aug 8, 2004 - 8:23 PM
Lo-Fi Version Time is now: November 30th, 2024 - 6:38 PM
