Soldering in LED's, resistor ? |
Aug 15, 2004 - 8:06 PM |
Enthusiast Joined Sep 24, '03 From Medina, OH Currently Offline Reputation: 11 (100%) |
i did a search but if you want to change climate control light colors ( i know it not REALLY climate control) why do you need resistors? (im electrical stupid) why cant you un-solder the green ones and solder in the blue ones it would make everything soo much simpler than all this talk about running resistors and what not soooo if someone could elaborate on this a lil for me it would be greatly appreciated!
Aug 15, 2004 - 8:19 PM |
Moderator Joined Apr 17, '03 From Rockland NY Currently Offline Reputation: 15 (100%) |
you can solder the indicator leds directly to the board. however the leds to light up the unit would need resistors cause you cant screw them in like the 3 bulbs you are replacing.
here is what to do for the leds that need resistors. you need to find a power source that turns on with ur lights. run ur positive from there, add a 220 ohm resistor to the wire then attach the led, now find a negative source and attach it to the negative led strip. you'll find that ur leds will shine really brite. then you can postition them anywhere in the unit you'll have to do this atleast three or four times but you cna use the same source for power. people will say you dont need resistors... trust me I have done it with and with out resistors. with resistors looks the best. let me know if you need any help later DEF -------------------- I will return one day. |
Aug 15, 2004 - 9:05 PM |
Ohh so the resistors acctually (sp?) will make the LED's brighter by using an outside 12volt source? hmm makes sence but since im going with different color buttons ill try w/o them first i can always add them later i guess i really wanted to make sure they would light up and not fry anything important lol thanks for you help
Aug 15, 2004 - 9:22 PM |
you dont need resistors for the leds you replace on the board. but you will need them when you replace the bulbs with leds. cause you cant screw the leds into the board like the bulbs. thats where the new power source comes in good luck -------------------- I will return one day. |
Aug 15, 2004 - 11:02 PM |
ohh ok i see well i just wanted to replace the LED's i already painted the bulbs - thats where i was getting comfused i understand now thanks for your help!
Aug 15, 2004 - 11:07 PM |
no prob take some pics when ur done -------------------- I will return one day. |
Aug 15, 2004 - 11:19 PM |
will do and i still have to figure out how to work my digi cam to post pics of my car too and thanks again
Aug 18, 2004 - 3:41 PM |
Enthusiast Joined May 20, '04 From Saskatoon, SK, Canada Currently Offline Reputation: 0 (0%) |
ok, so if I only want to replace the A/C light with a blue LED, I don't have to worry about adding a resistor, correct?
The resistors are just for the 3 bulbs that provide the illumination? I'm going to go searching through the forums now, but I might as well ask the question in this post if someone's going to reply to it anyway: What model/part# of blue LEDs have people used to replace the A/C light (and other smaller lights like it)? Thanks, Kevin |
Lo-Fi Version | Time is now: December 4th, 2024 - 3:46 PM |
