> Vortec FMU, which to get for 5sfte project
post Sep 2, 2004 - 1:21 AM
NEVERSTOP
Joined Nov 4, '02
From Davenport Iowa
well originally was goin to go with a 8:1 FMU but have a chance to get the 12:1 for pretty cheap.. do you guys think this would be too much for the 5sfte?
Thanks
99 project version 3.0.. hello SEMA 2010 =)
post Sep 2, 2004 - 1:25 AM
doGGy
Joined Oct 28, '02
From Europe, Lithuania
get RR FPR, it will be better, you will be able to adjust the pressure like you want.
12:1 is a bit too much Matt. I sugest going with 8:1
<<<<<< DCw / JDMart >>>>>>>
post Sep 2, 2004 - 1:32 AM
NEVERSTOP
Joined Nov 4, '02
From Davenport Iowa
okay thats kinda what I though.. what about a 4:1?
post Sep 2, 2004 - 9:22 AM
turboinduction
Joined Feb 25, '04
From Wisconsin
QUOTE (NEVERSTOP @ Sep 2, 2004 - 1:32 AM)
8.5:1 would be perfect
4 is way to low - you wont be able to move the car until the turbo spools and 12... well... cut a hole in your hood so you dont damage it when the block goes up in the air.
post Sep 2, 2004 - 10:11 AM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
12:1 will make you run stupid rich
hold out for an 8:1
1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram
post Sep 2, 2004 - 12:26 PM
NEVERSTOP
Joined Nov 4, '02
From Davenport Iowa
well think I might try the 4:1 at first just cuz the price I can get that one for.. and if I think its runnin too lean i'll swith to a 8:1 diafram (sp?). I'm running a warblo supra fuel pump and the fuel lines are new also so think I should be alright.. if not I'll know right away and swap it out to 8:1
post Sep 2, 2004 - 1:32 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE (NEVERSTOP @ Sep 2, 2004 - 9:26 AM)
um
i think its better to start with a rich running setup then leaning it out.
more than likely 4:1 will run really lean. if you want one right away, get the deal on the 12:1 and then switch to the 8:1 diaphram. its safer.
post Sep 2, 2004 - 1:41 PM
nik
Joined Sep 30, '02
http://www.vortechsuperchargers.com/produc...l/fuel_fmu.html
if you get a 12:1 you can get this to change ratios
post Sep 2, 2004 - 2:08 PM
Why not get the higher pressure one and a regulator in case you need more down the road?
post Sep 2, 2004 - 8:13 PM
hyp3rk1d
Joined Sep 22, '03
i got a 10:1 Vortech.. just to be safe wink.gif
post Sep 2, 2004 - 11:50 PM
NEVERSTOP
Joined Nov 4, '02
From Davenport Iowa
well I only plan on running around 5-6psi tops and 3 for daily driving.. so I don't wanna run rich all the time.. thats why im leanin towards the 4:1 now instead of ne of the others.. was gonna get the 12:1 just cuz of the price... who knows but I gotta figure something out..
The 5sfte will work without a FMU correct?
post Sep 3, 2004 - 1:23 AM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE (NEVERSTOP @ Sep 2, 2004 - 8:50 PM)
only if u have bigger injectors and a 2 bar map
SAFC would work too
post Sep 3, 2004 - 1:34 AM
NEVERSTOP
Joined Nov 4, '02
From Davenport Iowa
I got the 2 bar map and workin on bigger injectors, got the supra TT pump also... just cant seem to figure out if Its the green or yellow tops I need.. belive green but can only find yellows frown.gif
Lo-Fi Version Time is now: January 16th, 2025 - 12:57 AM
