> 5SFE Supercharged vs. Swapped 3SGTE, me rambling
post Sep 4, 2004 - 10:38 PM
o8poa8o
Joined Jun 11, '04
From Wake Forest, NC
i've seen some discussions about a Supercharged 5SFE thought i should share my opinions.....
Ripp Mods Supercharger (around $3400) you can be pushing "reliable" 227.3 horsepower at 9psi, you'll also need a "boost cooler" to run over 8psi.
Now to the rambling...
Most people have a 2nd generation 3SGTE just because there easier to find then the 3rd, and are more advanced than the 1st generation 3SGTE's. The JDM 2nd Generation 3SGTE pushes out 225hp and similar torque numbers (USD is 200hp).
Lets say with the 3sgte your going to buy a complete front clip, well $3,500 sounds like a good price, well add another $1500 for labor (for celica owners who aren't good when it comes to mechanic's, or dont have a place to perform there swap, or don't have the time to do it), and another $750-1000 for custom exhaust, clutch, an intake, etc...
that comes out to around $5785 oh yea plus the $100 your going to have to slip the guy at the emissions shop, and countless small piece's you'll have to replace, you will be just around $6000 with a Turbocharged 2.0L 3SGTE with around 50,000 miles......
Now for the Supercharger, its cost $3400, and you'll need a boost cooler if you want to go over 8psi (and you know you will!) so put down another $500, plus around $400 for labor (for the mechanically inclined), and $700 for a custom cat-back, intake, maybe some new sparkplugs, oh lets throw in some new wiring for looks, well your right at $5000, sounds good, now you have your 5SFZE with quite a few miles on it, pushing around 240hp at the crank.
now about those miles you have on your engine, before you put that nice supercharger, why not shop around alittle, many people on this site, and on ebay, and countless other sites are selling low mileage 5sfe's, and you can get a basic rebuilt for around $750, now your at the $5750 mark...
Now right now both engines should be pushing the 240hp mark if not over it, both are nearly the same price, now which ones for you?
Lets see here we'll start with the 3SGTE
its a factory engine, so reliablity isn't really an issue, then again it can if your mechanic is mentally challanged like coomers (4age swap), but you should be set for reliablity, now to practical, is it? well yes, alittle turbo lag but nothing thats going to make it terrible for everyday driving, sure the engine is used, but it is at its factory settings (if you haven't started modding it yet), so you should be set.
SLOWCELICA94 stated that one has forged internals, and that made me think about, later if you want to upgrade your engine to put out even more, than you can do much more with the 5SFZE unless you want to replace all the internals, and such, and the 3SGTE will be good for another 80-100hp before you have to get inside and start changing internals.
now for the 5SFZE
This is not a factory supercharged engine, who knows if toyota ever had this come into their heads, but rippmods has a 1 year warrenty, and you have a freshly rebuilt engine, so you should be good right? yes you should at first, but after a year or two, your internals will be wearing badly, the 5S block wasn't made for forced induction, so after that warrenty is up you could start having some problems, oh and for practibility i'd think this would win for the everyday driver, just because the supercharger provides boost at such low rpms, you'll get loads of low end torque.
anyways, in the long run, i'd say you guys should stick with the 3SGTE swaps...
lol, im bored, and i've been comparing the two engines in my head for a few days, thought i should share...
Brian
This post has been edited by o8poa8o: Sep 6, 2004 - 3:11 PM
post Sep 4, 2004 - 10:57 PM
hs2g
Joined Aug 26, '04
From St. Cloud, Minnesota
Nice information. I was thinking the same thing a couple of days ago.
post Sep 6, 2004 - 10:02 AM
o8poa8o
Joined Jun 11, '04
yea i saw acouple people talking about it, so i figured i should go ahead and saw what i was thinkin
post Sep 6, 2004 - 11:01 AM
Doge
Joined Dec 2, '02
From Portland, Oregon
3500 for a clip is very high. Most sell for between 1500 and 2500... but the numbers are still right... you forgot some stuff to factor in so it still comes out to about 6k.
post Sep 6, 2004 - 11:38 AM
thats why the SC is not selling well for Ripp.
you can get a clip for around 2,500 shipped for a 2nd gen and 3,500 for a 3rd.
post Sep 6, 2004 - 2:55 PM
SlowCelica94
Joined Sep 28, '03
From Bloomington, IN
one has forged internals, one doesnt
92 Civic hatch B16 - Sold
10th anniv RX-7 - RIP
post Sep 6, 2004 - 3:08 PM
o8poa8o
Joined Jun 11, '04
yea i was just estimating, thanks for the comments
post Sep 6, 2004 - 8:17 PM
orvillescelica
QUOTE (o8poa8o @ Sep 4, 2004 - 8:38 PM)
At the ripp mods site, it says the "boost cooler" comes with the kit as well as a digital controller for it. So i think you should take that $500 from your total. If by "boost cooler" you meant an intercooler, than that $500 is fine.
post Sep 6, 2004 - 8:22 PM
oh a supercharger, you change the amount of boost by installing a new size pulley on it. it donst bleed off boost from a wastegate like a turbo, so there are no boost controlers or anything like that.
i bleieve that Ripp uses water injection insted of an intercooler.
in all honesty, this is the best thing out there for anyone wanting to make more power from their 5sfe. the desing and tuning of this kit is far better then any 5sftes around.
post Sep 7, 2004 - 4:57 PM
o8poa8o
Joined Jun 11, '04
QUOTE (lagos @ Sep 7, 2004 - 1:22 AM)
yea thats a good point, but they dont sell belt tensioners or new pulleys (belts)... plus if you do much more boost your going to need to build up the internals, but it is great if you just want a low 14's celica... again thanks for the comments
post Sep 7, 2004 - 5:11 PM
Given the choices, I'd go 3S-GTE. I'll hopefully end up with a 3S-GTE-swapped Celica within a couple years. smile.gif
However, a swap can sometimes suck...it took over a year after my swap for my car to finally begin running right. And it's not just my very stupid mechanic...other people have had trouble with swaps as well. And with a swap, there will be more downtime, and stuff is much more likely to go wrong with the actual labor/wiring. Just something to consider. wink.gif
post Sep 7, 2004 - 6:16 PM
Silver94CelicaOw...
Joined Oct 13, '02
From Blairstown, New Jersey
i'm personally starting to have more faith in the 5SFE as a engine worthy of tuning. I searched for "5SFTE" on yahoo last night and got tons of MR2 owners and Celica owners with turbos, some with over 10 psi on stock internals with excellent reliability.
One former N/A MR2 ran a 10.9(!?!) with a highly-tuned turbo setup complemented by forged pistons, shot-peened rods, and Webcams camshaft regrinds...good for a dyno proven 515hp/355tq...so the 5SFE can definately use boost and use it well if done right. wink.gif
Link-
Video of Boosted 5SFE MR2- 10.9 second pass
Enjoy.
EDIT- More info regarding his setup plus a dyno chart- (click for bigger image)
5SFTE motor - ACT clutch, Ported & polished head, Web Cams, Aeromotive Eliminator pump, JE Pistons, Crower rods, Stiffer valve springs, Stainless steal valves, T series Turbo,DFI ECU, 50 shot NOS,Custom intake, tubular exhaust manifold,850cc injectors,Spearco intercooler, 3inch intercooler piping, Greedy type R blow off valve
This post has been edited by Silver94CelicaOwner: Sep 7, 2004 - 6:24 PM
post Sep 7, 2004 - 6:22 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE (Silver94CelicaOwner @ Sep 7, 2004 - 3:16 PM)
any engine has potential with enough money and enough boost.
1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram
post Sep 7, 2004 - 7:36 PM
CaRson-Masta
Joined Jun 13, '04
From NV
I would have to agree with coomer i have done tons and TONS of research on the 3sgte swap and have found out that the wiring can be one hell of a problem and just the swap in general can tak a LONG time frown.gif . But I'm sure that it would most likely pay off in the long run cus.... the 3sgte destroys all lol. But to save ureself the head ache u could probably go with that supercharger but that still involves custom work but all in all i think that would be the easist way to spare all the head aches... Sry to here bout that coomer i would kill the machanic lol. mad.gif
post Sep 7, 2004 - 8:00 PM
acutally, the rippmods supercharger starts at 5lbs of boost, and the DO sell the 9lb and 11lb pulleys.. wink.gif
post Sep 8, 2004 - 1:57 AM
Doge
Joined Dec 2, '02
QUOTE (o8poa8o @ Sep 7, 2004 - 2:57 PM)
Low 14 is a little overestimated... I dont think it would make it that fast.
post Sep 8, 2004 - 4:27 PM
o8poa8o
Joined Jun 11, '04
pressure2 i didn't see any pulley's over 9psi but i'll look again
doge it was just a estimate, i could very well be to low, but at 9psi, w/ exhaust, intake, good tires, good driver, i dont think a time around 14.3-14.4 1/4mile is too far off.
Lo-Fi Version Time is now: February 17th, 2025 - 1:33 PM
