koni shocks |
koni shocks |
Sep 7, 2004 - 11:08 AM |
Enthusiast Joined Oct 19, '02 From Spring Valley, NY Currently Offline Reputation: 1 (100%) |
anyone who has them(koni yellow shocks) can you please IM me...i need some info and kinda confused....
thanx alex AIM: Jigglypup18 |
Sep 7, 2004 - 11:21 AM |
aite just to make it easier so i dont have to say it more than once...i have kyb gr2's shocks now but their dead and i need to replace them...i wan konis cuz their adjustable but the question is....do u get 2 cartridge for the rears and 2 whole housing for the fronts?? OR[B] do u get 4 cartridges?? someone told me that it was 4 cartridges and that the 2 fronts have to be welded...but importhorizon.com has told me that only 2 are cartrdiges....so i'm kinda confused...any answer would be greatly appreciated
thanx alex |
Sep 7, 2004 - 11:32 AM |
You get four shocks. The fronts aren't the problem though, as your KYBs were just shocks for the fronts as well. The problem is that you have to cut and weld your rear struts in order to remove the old shocks and put the Koni shocks in.
Sep 7, 2004 - 10:12 PM |
Enthusiast Joined Mar 2, '04 From Louisiana, USA Currently Offline Reputation: 2 (100%) |
No welding is required (provided you use OEM KYB rear struts). If you've got GR-2s, you will probably have more problems installing the Konis. Hopefully some other people will give you more information on GR-2 to Koni installation.
Sep 12, 2004 - 11:31 AM |
Enthusiast Joined Oct 30, '03 From IL Currently Offline Reputation: 15 (100%) |
how long does the KYB struts last?
-------------------- PROJECT 6TH GEN
<FS: Things up for grabs> <Progress> |
Sep 22, 2004 - 11:23 AM |
Enthusiast Joined Nov 16, '03 From Italy - Como Currently Offline Reputation: 0 (0%) |
i have installed custom Bilstein shock and eibach spring, 1800€, are not adjustable.
the koni adjustable shock with eibach spring costs 1.400€ but are all for gtfour......... absorbers 1 absorbers2 absorbers3 |
Lo-Fi Version | Time is now: December 2nd, 2024 - 11:53 PM |
