> FS: HKS FCD + Restriction style MBC
post Sep 10, 2004 - 6:54 PM
boosted_K2
Joined Aug 30, '02
From Michigan
will have pics soon. as it states, combo set of a HKS FCD (fuel cut defender) and a Restriction style MBC (manual boost controller). all you need to get seperately is a set of 2 silicon vac hoses and you will have everything you need to adjust your boost pressure.
if using the FCD on a 2nd gen 3sgte motor, setting # 7 will eliminate the fuel cut and setting #9 sets it to 17.5 PSI
best offer takes it, basic price for the MBC is 35 bucks and a brand new FCD is a little over 100. this FCD is slightly used but in good working shape.
also this restriction style MBC does NOT require you to disconnect the T/VSV.
No but I don't buy it
Cause I'm...
post Sep 11, 2004 - 11:42 AM
boosted_K2
Joined Aug 30, '02
From Michigan
bump for a pic
http://www.we-todd-did-racing.com/wetoddim...zMXk1NDE%3D.jpg
Cause I'm...
post Sep 11, 2004 - 12:49 PM
ghostdog
From ny to philly
how much for the got boost sticker?
post Sep 11, 2004 - 1:58 PM
boosted_K2
Joined Aug 30, '02
From Michigan
Cause I'm...
post Sep 12, 2004 - 5:26 PM
boosted_K2
Joined Aug 30, '02
From Michigan
bump
Cause I'm...
post Sep 13, 2004 - 10:03 PM
boosted_K2
Joined Aug 30, '02
From Michigan
sale pending on the FCD, got boost sticker and MBC still for sale, 35 shipped.
Cause I'm...
post Sep 13, 2004 - 10:16 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
the FCD u think that will work on my 5sfte? since im using a 3sgte map (turbo senor)?
post Sep 14, 2004 - 9:07 AM
boosted_K2
Joined Aug 30, '02
From Michigan
the FCD doesnt deal with the sensor, it deals with the ecu. i wouldnt expect you to need it because it removes the fuel cut due to pressure spikes, the 5sfe doesnt have a boost pressure sensor, so it wouldnt do anything for ya.
Cause I'm...
Lo-Fi Version Time is now: February 24th, 2025 - 6:55 PM
