> wait a sec..., am i a genius or a complete idiot
post Sep 21, 2004 - 4:28 PM
pistatio56
Joined Nov 14, '02
From Chicago
what if you took the late model 3S-GE top end (with VVT-i) and put in on the 3S-GTE?
would you have toyota reliability on a turbo motor with VVT-i?
or am i just an idiot and there is an obvious reason it won't work.
my signature is the coolest.
give me your celica.
post Sep 21, 2004 - 4:34 PM
ghostdog
From ny to philly
possible but not worth it. variable cam timing isn't beneficial for boosted vehicles.
post Sep 21, 2004 - 4:50 PM
Magic
Joined Mar 30, '03
From Cyprus
There is no way to work..... smile.gif What a wild block have to do with the low compression block of the 3SGTE???...I think its nice move if you take the block from a 3SGE(VVTI) and put it on a 3SGE non-VVTI block... smile.gif you could have better results......
If you want to extend the duration with wilder camshaft profile HKS and JUN has very nice camshaft kits for 3S block smile.gif and trust me...its cheaper.
post Sep 21, 2004 - 8:54 PM
or you could buy a 10$ boost controller off ebay and get 10x the gain VVT-i would give u, in just a baisc 3sgte.
post Sep 21, 2004 - 8:55 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
VVTi is like computer controlled cam gear...
post Sep 21, 2004 - 10:33 PM
Shigexile
Joined Oct 30, '03
From IL
But i thought the Supra has a VVT-i? Or is it the VVTL-i?
Edit: what's the difference?
This post has been edited by Shigexile: Sep 21, 2004 - 10:45 PM
post Sep 22, 2004 - 1:35 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE (Shigexile @ Sep 22, 2004 - 3:33 AM)
Later models of the 2JZ did have VVTi. I don't think it ever made it to the USDM supras... but I dunno. If it did, it was in the late model 97+...
As for VVTi and VVTLi... it can be as much as 40 hp difference (1zzfe vs. 2zzge). VVTL-i works similar to VTEC and provides variable cam lift and timing...
post Sep 22, 2004 - 9:49 AM
rlan214
Joined Dec 27, '02
From Sleep in Warren chill in clinton twp, works/school in detroit
my sis 95 supra has vvti
post Sep 22, 2004 - 11:03 AM
flipside97LTD
Joined Nov 29, '03
From Hampton, VA
post Sep 22, 2004 - 5:31 PM
Junior
Joined May 5, '03
From Toronto
If you check out any race vehicle from honda or toyota, you'll see that neither of them have vtec or VVTi. Regardless of turbo or NA. More aggressive cams don't have variable valve timing. Turbo charging a car with vtec or VVTi, won't reach full potential because the cams have too much overlap.
post Sep 22, 2004 - 10:03 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE (Junior @ Sep 22, 2004 - 10:31 PM)
VTEC and VVTL-i are not designed for race. They are designed to make "STREETABLE" horsepower. Of course, it would only make sense that their non-street race engines don't need to be cluttered with VTEC or VVTL-i. Agressive cam profiles can make a lot of power with good tuning on a Turbo car.
Lo-Fi Version Time is now: February 21st, 2025 - 4:26 AM
