> 3s-gte swap
post Mar 8, 2003 - 11:19 AM
WarriorPride67
Joined Nov 12, '02
From Charleston SC
So the 3s-gte swap is gonna take more work for my ST? I really want to do this swap and is there any way we can purchase the engine straight from japan?
post Mar 8, 2003 - 12:39 PM
mywhite94celicag...
Joined Oct 30, '02
From Nebraska
there is an import shop near my hometown where i can buy the 2nd gen of the sgte, the 225hp version, that comeswith the ecu and wiring harness $1,000. That is for shipping also, straight from Japan. cwm13.gif
This post has been edited by mywhite94celicagt: Mar 29, 2003 - 11:43 PM
94 celica GT
90 Civic Si
post Mar 8, 2003 - 2:15 PM
The JDM ST185 3SGTE is 225 HP, the 200 is USDM.
post Mar 9, 2003 - 5:37 PM
95STCelica
Joined Oct 12, '02
From New Jersey
if you get it for your st you will need the gt motor mounts also
post Mar 9, 2003 - 8:58 PM
and maybe a transmission. MR2 Turbo, Camry V6, or Celica GT tranny's will all do fine.
post Mar 9, 2003 - 11:33 PM
FallenHero
Joined Dec 26, '02
From Alabama
Where did you find it for 1g?
post Mar 9, 2003 - 11:56 PM
hiflytsi
Joined Jan 9, '03
From Concord, NC
Has anyone heard any stories about how good the camry v6 tranny is, and also does it come with LSD, also, does the mr2 tranny come with LSD?
post Mar 10, 2003 - 1:19 AM
Neipas09
Joined Sep 5, '02
From Phoenix, AZ
I would go with the MR2 tranny since it was built to handle a turboed engine.
post Mar 11, 2003 - 8:19 PM
hiflytsi
Joined Jan 9, '03
From Concord, NC
QUOTE (Neipas09 @ Mar 9, 2003 - 11:19 PM)
it doesn't really matter if it came from a turboed car or not, they both were made to handle higher extremities than your stock tranny, its just the mr2 is more resourceful than the camry. Now how about them ACIDS...!?
you know...acid?...lsd??...get it???
...oh forget it
Edit-
Not the question but the stupid joke I mean.
This post has been edited by hiflytsi: Mar 11, 2003 - 8:19 PM
post Mar 12, 2003 - 3:20 AM
zigy
Joined Nov 6, '02
From Chicago, IL
Dude screw half-cuts or whatever bull they are dealing with and go with http://www.atk-engines.com , ATK
does a special order and in a month or two you get an awesome engine. "3sgte" (6th gen Celica GT-4) is
around $ 2,300 (with warranty and free delivery)...
For trans you don't want to be dealing with anything else but stock 94-99 Celica GT 5-Speed Manual
Transmision (all you need to do is to get a performance clutch)...
Edit : Sorry forgot to mention engine mounts... If you are having a shop install the engine don't worry about it since they can make custom ones in less then half an hour and drill couple extra holes in a frame for the extra support!
This post has been edited by zigy: Mar 12, 2003 - 3:22 AM
post Mar 13, 2003 - 1:09 AM
NEVERSTOP
Joined Nov 4, '02
From Davenport Iowa
to swap the 3sgte into a ST you are going to need the full front clip...period.. otherwise there's alot of sorcing of parts.
you need the front axles out of the GT4 or GT cuz the ST ones will break.
also for the transmission you CAN NOT use the St one... it wont hook up.. also the GT or the Camary ones arnt the best options go with the MR2 one or use the one off of the 3sge engine cuz its gonna be the strongest front wheel trans you can get and is a straight bolt in on a 6th where the MR2 one needs some extra parts <--- not 100% on that but pretty sure
edit - u also need new motor mounts the GT ones usally work depending on what gen 3sgte you have
This post has been edited by NEVERSTOP: Mar 14, 2003 - 12:41 AM
99 project version 3.0.. hello SEMA 2010 =)
post Mar 13, 2003 - 2:46 AM
j2cute32
Joined Jan 14, '03
From miami,fl
QUOTE (zigy @ Mar 12, 2003 - 1:20 AM)
can you find out how much is the st85 2nd gen is for me with about 70k or less. confused.gif biggrin.gif
post Mar 13, 2003 - 3:48 AM
Neipas09
Joined Sep 5, '02
From Phoenix, AZ
If the engine doesn't come with a ECU and Wiring harness, then you might as well not even bother.
post Mar 14, 2003 - 12:41 AM
NEVERSTOP
Joined Nov 4, '02
From Davenport Iowa
clips come with that
post Mar 14, 2003 - 5:39 AM
Neipas09
Joined Sep 5, '02
From Phoenix, AZ
QUOTE (NEVERSTOP @ Mar 13, 2003 - 10:41 PM)
DUH!!!
I was talkin about all the f00s out there that find a sweet deal on a 3S-GTE ST205 engine for like $1000 off ebay or whatever and all they get is the engine and nothing else.
post Mar 15, 2003 - 12:31 AM
NEVERSTOP
Joined Nov 4, '02
From Davenport Iowa
DUH!!!
was just clarifyin myself man
post Mar 16, 2003 - 9:48 PM
hiflytsi
Joined Jan 9, '03
From Concord, NC
Good informative posts guys... now can anyone tell me IF ANY TRANNY COMES WITH AN LSD!!!! AHHHHH!!! please.
post Mar 17, 2003 - 1:09 AM
Neipas09
Joined Sep 5, '02
From Phoenix, AZ
no probly not
LSD's are something extra you buy for a tranny.
Just an aftermarket part like a Stage 2 clutch that you have to buy seperate unless it already comes with the tranny you buy.
post Mar 17, 2003 - 1:12 AM
NEVERSTOP
Joined Nov 4, '02
From Davenport Iowa
TRD makes the LSD's for all of there trannys.. you will have to call them though for most of them
post Mar 18, 2003 - 5:40 PM
Most of the JDM's come with a cut harness, and even if they didnt, u would have to cut it anyway to extend it...anybody kno of any wiring diagrams to make this any easier?
Lo-Fi Version Time is now: November 28th, 2024 - 8:57 AM
