> stock fuel injectors
post Oct 2, 2004 - 1:15 AM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
allright i've been doing some research on injectors and this is the deal i have a turbo setup already with a fmu. i would like to keep the stock injectors which are 5sfe injectors and i did some math and they flow at approximately 20.8 lbs. i have a fmu but it's at a 4:1 ratio. on vortech's site they have a ratio of 10:1 which will flow 19lbs. will this ratio work? eventually i'll be getting 7mge injectors. and i've also searched on fuel pumps and people are running with their stock fuel pumps but i'm assuming thier running their stock injectors. will i be fine with this setup before i throw everything on? any suggestions ?
thank you
Rick
This post has been edited by rjbibeau: Oct 2, 2004 - 1:17 AM
post Oct 2, 2004 - 9:54 AM
psyko
Joined May 18, '04
From Charlotte, NC
i've always heard of people blowing the fuel pump at least on the st, so they use the 255lph fuel pump
post Oct 2, 2004 - 1:04 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
allright thanks for the info but i have a gt are they the same pumps?
post Oct 3, 2004 - 5:34 PM
psyko
Joined May 18, '04
From Charlotte, NC
someone yell at me if i'm wrong i think they have the same pump, maybe different injectors, i'm not really sure.
Lo-Fi Version Time is now: November 28th, 2024 - 11:40 AM
