> big brake kit
post Oct 6, 2004 - 9:48 PM
CELICAKIDD324
Joined Oct 4, '03
From CENTRAL, NY
does anyone know where i can find a big brake kit for a 6th gen, i saw a gt-4 in a japanese mag that had the front ones, anyone know how to get them or what they maybe off of?
[img][http://memimage.cardomain.net/member_images/12/web/516000-516999/516799_123_full.jpg/IMG]
post Oct 6, 2004 - 10:13 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE (CELICAKIDD324 @ Oct 7, 2004 - 2:48 AM)
The GT-4 has a different brake and suspension set-up... so those won't work on our USDM cars... however, It's been said the 7th gen shares the same hub splines with the 6th gens... so the 7th gen big brake kit *should* work...
post Oct 6, 2004 - 10:42 PM
shadycrew31
Joined Jun 29, '03
From canoga park , ca
yes the 7th gen big brake will fit an st not a gt. .
post Oct 6, 2004 - 10:45 PM
Ale_lock
From New York City, NY
QUOTE (shadycrew31 @ Oct 6, 2004 - 11:42 PM)
How is it gonna fit a GT but not a ST when its basically the same except for GT's being all-wheel disks...
post Oct 7, 2004 - 12:00 AM
Consynx
Joined Dec 25, '02
From Pittsburgh/Clairton, PA
there's a dif somehow
i know the "fit kit" for the brake pads are dif b/t the AT200 and ST204 frown.gif
i dont get it though
post Oct 7, 2004 - 12:15 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE (shadycrew31 @ Oct 7, 2004 - 3:42 AM)
Umm... will fit either ST or GT. The outer axle shafts are of the same spline count, so it'll fit either or. The ST does have a different/smaller front brake set-up than the GT, but the front hubs are completely swappable. I believe all of the FWD Celicas share the same spline count for the fronts and the rears are all similar enough to be swappable.
post Oct 7, 2004 - 1:52 AM
shadycrew31
Joined Jun 29, '03
well why dont you go buy a brembo set of brakes for a gt. and try and fit them on your st. opps wont work. tried it and so did others.
post Oct 7, 2004 - 11:13 AM
Consynx
Joined Dec 25, '02
numberous people spent $1200 on a guess?
hope it was worth the try.
unless you're talking about just pads? or rotors?
post Oct 7, 2004 - 6:50 PM
S_C_M
Joined Mar 2, '04
From Louisiana, USA
QUOTE (shadycrew31 @ Oct 7, 2004 - 6:52 AM)
I think you're talking about a Brembo OE replacement set of discs for a 6th Gen GT (that may or may not have been drilled/slotted). You'd need GT calipers, pads and mounting brackets for this to work. I've done it; it works pretty well but I'd like to have something more substantial. Perhaps a 7th Gen big brake kit is the way to go, I just don't want to be the first guy to attempt it.
post Oct 8, 2004 - 1:10 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
Cause you need the hub genius... rolleyes.gif can't just "bolt" everything up.
post Oct 8, 2004 - 4:42 AM
shadycrew31
Joined Jun 29, '03
ehh im done. buy a big brake for the gt see what happens.
post Oct 8, 2004 - 11:48 AM
Consynx
Joined Dec 25, '02
find SpeedToe and contact him about this to find out more...that's my advice, as i see him as the god of suspension smile.gif
post Oct 19, 2004 - 1:32 PM
Nemises
Joined May 6, '04
From antioch CA
I thought the only difference between the two was the size of the backing plate. When I did my st to GT conversion the junkyard gave me the whole spindle all i used was the backing plate and all the GT stuff bolted right on no problem.
post Oct 20, 2004 - 8:54 PM
droptopGT
Joined Apr 12, '04
From Nj Team 6gc
mMmmm.. big brake kit... *drools*
Team 6gc 2oo5
post Oct 20, 2004 - 10:43 PM
recneps
Joined Jul 7, '04
From charlotte N.C.
is there anyway to increase braking without a big brake kit. when i had my gt i could hit the brakes really hard about 3 times (not locking them up) just to heat them up. and they would get so hot in just those 3 hard brakings that i couldnt even lock them up at all after that no matter how hard i tried.
any suggestions.
oh yeah buy the big brake kit ill bet its awesome. is ti made by TRD.
Former: 96 GT 5 speed (i/p/e) Fate- rear ended by mack truck
00 GTS 6 speed (i/ Bored TB 63mm - 68.5mm w/ butterfly/ Ported IM/ IMG/ PFC/ Commander/ datalogit/ Ported & heat wrapped Header/ Decat/ UEGO/) 193FWHP 14.2(1/4mi) @98mph, 2.12 60ft (just intake, unbolted Exhaust, and gutted) Fate- side swipped by 18 wheeler at 75mph.
Next: maybe an elise
post Oct 21, 2004 - 2:00 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE (recneps @ Oct 21, 2004 - 3:43 AM)
any suggestions.
Slotted rotors, performance pads... steel braided lines... maybe a rebuild? Those little things can dramatically increase braking performance.
post Oct 21, 2004 - 2:15 AM
Hanyo
Joined Aug 16, '03
From Bay area
wait.. steel braided lines help?
post Oct 21, 2004 - 5:24 AM
recneps
Joined Jul 7, '04
From charlotte N.C.
yeah wait how do they help?
post Oct 21, 2004 - 9:44 AM
FallenHero
Joined Dec 26, '02
From Alabama
when you apply pressure to them, they dont expand. (like the rubber ones.)
with the rubber, you stomp the brake, and they expand a bit because of the pressure. Steel braided doesn't do that. smile.gif
post Oct 21, 2004 - 11:49 AM
Consynx
Joined Dec 25, '02
are they as reliable though...
Lo-Fi Version Time is now: November 27th, 2024 - 8:33 AM
