HKS Super AFR - Abnormal Readings, Please help if possible... |
Oct 15, 2004 - 6:03 PM |
Enthusiast Joined Aug 27, '04 From Orange County, CA Currently Offline Reputation: 0 (0%) |
I've had an acceleration problem for quite some time now. Here is my past link when I origionally tried to see whats wrong.
http://www.6gc.net/forums/index.php?showtopic=15719&hl= I've move onto adjusting my HKS Super AFR and try to improve results with Air/Fuel mixture. I recently noticed some abnormal readings when accelerating. My all around fuel adjustment is set at 12%. I don't know if these numbers are relavent to the problem...but when my Boost Gage is at around 10psi of vacuum, and RPMs are around 2500-2700, it seems as if fuel is being cut off and shunts/stutters/loses power /etc. When this happens... my HKS Super AFR reads -00%. After I ease up on the pedal and reach a cruising speed and steady rpm, the display returns to its 12% setting that its programmed for. This has been going on for quite some time now, and although the new O2 sensor helped, I still sometimes need to reset the internal air/fuel mixture computer to get it riding smoothly again. If anyone can help me out, it would be awesome. Thanks. -------------------- |
Lo-Fi Version | Time is now: November 25th, 2024 - 10:25 AM |
