> Running engine Temp for the 5sfe?
post Nov 17, 2004 - 12:48 PM
95BlueGT
Joined Aug 30, '02
From Austin Texas
Just like the topic says? Anyone know what it is?
Also has anyone tried the RedLines Coolent for the Radiator which says it will drop the temp for up to 20 degrees? I bought it the other day, haven't put it in yet. Just wondering if anyone tried it?
post Nov 17, 2004 - 5:10 PM
recneps
Joined Jul 7, '04
From charlotte N.C.
its a bad idea to drop your engine temp. your engine was made to run at the temp it runs at, and it will have a bad affect on performance to drop the temperture that much.
Former: 96 GT 5 speed (i/p/e) Fate- rear ended by mack truck
00 GTS 6 speed (i/ Bored TB 63mm - 68.5mm w/ butterfly/ Ported IM/ IMG/ PFC/ Commander/ datalogit/ Ported & heat wrapped Header/ Decat/ UEGO/) 193FWHP 14.2(1/4mi) @98mph, 2.12 60ft (just intake, unbolted Exhaust, and gutted) Fate- side swipped by 18 wheeler at 75mph.
Next: maybe an elise
post Nov 19, 2004 - 1:10 PM
Nemises
Joined May 6, '04
From antioch CA
agreed it will make your engine run different and you probably wont have any heat.
post Nov 19, 2004 - 2:47 PM
95BlueGT
Joined Aug 30, '02
From Austin Texas
hmm interesting, i was always under the impression that the cooler the engine runs, the better performance you gain. i mean obviusly not as cold as when you start it up.
so what is the Running Temp for the 5sfe?
post Nov 19, 2004 - 5:34 PM
Anub1s
Joined Nov 27, '03
I think its around 180-185 or so but I'm not certain.
post Nov 19, 2004 - 8:25 PM
Clipsetuner
Joined Sep 12, '03
From Portland , Oregon , United States
20degree's thats iffy they all do about the same weather it be plastic or metal, if it is running cooler I would get a Thermostat that opens at a lower temp and should balance it all out. Good Ideer going with the metal tho, plastics ones can build under high pressure.
DTE
I am a thief.
do not buy anything from me.
Lo-Fi Version Time is now: February 17th, 2025 - 9:25 AM
