> Vibration at 75 MPH
post Nov 22, 2004 - 2:08 PM
exxtractor
Joined Mar 31, '03
From BC
I recently have noticed a bad vibration felt through the steering wheel (back/forth movement through the steering wheel) at arounf 75 MPH. Under that speed everything feels just fine, but over its defintely present. The only thing I can think of that has changed is 2 weeks ago they rotated tires. Any ideas on the cause?
post Nov 22, 2004 - 2:09 PM
balance your tires.
post Nov 22, 2004 - 3:59 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
do you have snow is your area if soo check the inside of the rim for ice chunks or snow that has built up. this will throw your tires off balance. it could also be mud chunks too.
post Nov 24, 2004 - 6:31 PM
gnetik
Joined Aug 14, '04
Yeah, its porbly the tires I had the same exact problem a few weeks ago. I changed my tires and got them balanced, and everything was cool after that.
post Nov 24, 2004 - 7:23 PM
C3L1CA
Joined Mar 11, '04
From Oakdale, MN
get your tires balanced, might be a bent rim. My dads car did this too but once we put his stock rims back on it went away.
-Brad
01 a4: daily
post Nov 24, 2004 - 8:54 PM
BLINKYxMUNKEY
Joined Nov 12, '03
From Crestview, Florida
when i put my wheels on the steering whell would shake. i then got some hub rings and put them on and that stopped the shaking. you should also check your wheels for balancing and for bent rims.
FlickR
post Nov 25, 2004 - 12:44 PM
exxtractor
Joined Mar 31, '03
From BC
This is my guess after they rotated the tires the set on the front was not balanced, however I 'll know in the spring, I just put my winters on with 14" steelies, and things seem fine. I'll keep you guys updated.
Thanks exx
post Nov 25, 2004 - 3:09 PM
macavely
Joined Nov 4, '02
simple problem... your wheels need to get balanced.... ..
post Nov 26, 2004 - 3:42 AM
exxtractor
Joined Mar 31, '03
From BC
finally a day without rain, drove around 80 mph without the vibration on my steelies which were balanced. When I switch back to my 16" wheels I'll get them balanced. Amazing how you only notice the vibration over 70MPH
post Dec 23, 2004 - 1:35 PM
D4W5
Joined Dec 15, '04
From newcastle england
my mate has a terd volvo and his did this,they tried the tyres and rims,but it is much worse,the axles or somthing,i'll get back when i ask him exactley what the prob is,have you had any work done to you g6 latley,garage might be responsible!
post Dec 23, 2004 - 2:05 PM
LatinKraze
Joined Oct 22, '03
Since this topic was resurected, I might as well ask:
I get a vibration in low gears between 0-30mph. What might it be? Anyone else have or did have this problem?
-Ivan-
Lo-Fi Version Time is now: December 3rd, 2024 - 8:29 PM
