Enthusiast ![]() Joined Nov 21, '04 From Central Valley CA Currently Offline Reputation: 0 (0%) ![]() |
From what I understand, swapping a 20v into an ST also involves swapping the wiring harness.
I've never worked with stand alone, so I have a dumb question here: Could a standalone be used to operate a 20v while leaving the stock 7A wiring harness in place? Why or why not? As detailed an explanation as possible would not be in vain, as I promise Ill soak it all up. =) |
![]() Administrator ![]() ![]() ![]() ![]() ![]() Joined Aug 23, '02 From Seattle, WA Currently Offline Reputation: 14 (100%) ![]() |
The stock 7A plugs don't fit the 20V 4A-GE. Also, some plugs are missing, such as the VVT plug and such. If you go standalone, I'd create a custom harness or use the 20V's harness.
Lo-Fi Version | Time is now: February 23rd, 2025 - 9:54 PM |
