![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jul 16, '04 From Los Angeles Currently Offline Reputation: 8 (100%) ![]() |
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...&category=33631
It looks like it would fit in the engine bay with a custom exhaust but i know it doesnt. But why? |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 8, '04 From LA Currently Offline Reputation: 0 (0%) ![]() |
The 5sfe engine in an mr2 are at a pretty big angle is the reason I believe
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Jul 19, '04 From Los Angeles, CA Currently Offline Reputation: 2 (100%) ![]() |
I think the top part would bolt on, but the bottem would have to be modified/remade.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 30, '02 From Maryland Currently Offline Reputation: 8 (100%) ![]() |
The top half will fit fine to the block. The bottom of that will have to be cut or modded in a way so that it will bolt up to our exhaust.
-------------------- Member of Team 5sfTe
Enthusiast ![]() ![]() ![]() ![]() Joined Apr 22, '04 From illinois Currently Offline Reputation: 0 (0%) ![]() |
i've explained this countlessly number of times. Search for it. But anyways, lets say this, if you put a header on your celi 5sfe that was made for the mr2, the end of the header (name please, forgot i did), would literally be pointing at the ground. The Mr2 engine is not at an angle, our engine is. The Mr2 is flat in the engine bay, where our engine has a good 60 degree twist on it.
-------------------- ![]() The most important lesson I learned from Karate-Dō Kyōshan – “You can not be what you do not believe you are” |
QUOTE(spunky393 @ Dec 16, 2004 - 2:39 AM) i've explained this countlessly number of times. Search for it. But anyways, lets say this, if you put a header on your celi 5sfe that was made for the mr2, the end of the header (name please, forgot i did), would literally be pointing at the ground. The Mr2 engine is not at an angle, our engine is. The Mr2 is flat in the engine bay, where our engine has a good 60 degree twist on it. [right][snapback]222030[/snapback][/right] I meant in relation to our engine, its at an angle ![]() |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 23, '03 From New Orleans Currently Offline Reputation: 5 (100%) ![]() |
screw it, i'm buying one and letting y'all know how much fun it is to make it work. I'll let y'all know after christmas how it goes.
the downpipe will probably have to be totally custom but hey friend's dad is a boiler maker, think i can learn some stuff from him
QUOTE(chucho @ Dec 16, 2004 - 2:55 AM) screw it, i'm buying one and letting y'all know how much fun it is to make it work. I'll let y'all know after christmas how it goes. [right][snapback]222044[/snapback][/right] For 90 bucks, it's not that much of a loss if it doesn't work. Also, you can probably have the second part made pretty cheaply. |
haha, thanks shid.
Was that put well enough to understand? -------------------- ![]() The most important lesson I learned from Karate-Dō Kyōshan – “You can not be what you do not believe you are” |
whoops, i need to read before i reply, well, good look chucho
thats just what i was thinking.
Makin things on ur own is so kick @$$. Dad has a welder and i think ill learn to use it lol. New project weeee This post has been edited by urbandork: Dec 16, 2004 - 1:40 AM |
Lo-Fi Version | Time is now: February 20th, 2025 - 4:33 AM |
