> Im water cooled baby!, ya leet pimp styley
post Dec 17, 2004 - 11:48 PM
Uppitycracker
Joined Jul 12, '03
From Chatham, Ont
Well after about a month of shopping messing around and problems I finally have my whole WC setup running!
CPU Idle Temp
GPU Idle temp
GPU Load temp
Im pretty happy with the temps, they seem to be lower then alot of the temps I read about. I know the on board thermal probes differ from actual temps so if someone wants to translate the above temps for me that would be cool.
Bleeding the lines
Maze4 CPU block
Moment of truth, my comp still works after tearing it apart!!!
Side shot
The external box, having no shroud really circulates the are keeping it cold in the box, so my pump stays cool aswell as the rad and lines.
Tomorrow I need to run over and get a plug for my t-line, then I can actually close it all up.
Noise is a little higher then Id like, Ill try and do something about that in the coming weeks.
I know its out of the ordinary to go through the side but I dont have the tools to cut through thick steel, and yes my case has some really thick sturdy steel, so I just cut through the plastic side vent.
Any questions or suggestions are welcome, Im sure Ive missed something.
post Dec 17, 2004 - 11:51 PM
Akimbo
Joined Jun 30, '03
From O-town, FL
WRC PC
- Ryan
aim: rkgreen04
post Dec 18, 2004 - 12:34 AM
celicarocker
Joined Sep 25, '03
From cranston RI
personally id get annoyed with a little box next to my computer, but i know you didnt have many options... it looks like you did a sweet job d00d....
post Dec 18, 2004 - 1:25 AM
Uppitycracker
Joined Jul 12, '03
From Chatham, Ont
QUOTE(celicarocker @ Dec 17, 2004 - 10:34 PM)
[right][snapback]223178[/snapback][/right]
Oh for sure man, Id so prefer it all internal but my comp case is the anti water cooling case. In retrospect I maybe should have shopped for Lian li case or something but that probably would have added alot of money to the build since the plexi glass was 35USD and I only used half, so I guess you could say it was 15 bucks.
post Dec 18, 2004 - 3:18 AM
Anub1s
Joined Nov 27, '03
That is one bad ass pc I love it. Very well done.
post Dec 18, 2004 - 1:10 PM
Sev408
Joined Dec 4, '03
well heres mine ill get a pic wiht the door closed later tonight when its dark.
yes the wires are messy but that was during my WC leak test and none of the fans were connected, now all hte wires are hiden behind the board.
PS. i broke the fitting for teh radiator cause my teflon got lodged and it got over turned so it snaped, so thats my makeshift and it works better then the fittings that came with the rad.
my geforce 5900 is OC to 450/800 right now
CPU temp is 32c/86F
GPU temp is 31C
mind you asus probe and nvidia temps are always +-3 degrees. I need to get an accuall temp monitor to find my real temps out.
This post has been edited by Sev408: Dec 18, 2004 - 2:04 PM
user posted image hows it taste motha f*cka
post Dec 18, 2004 - 1:19 PM
coustoe
Joined Sep 18, '02
From Northern, Virginia
hmm, how much performance % do you get with oc and cooling?
post Dec 18, 2004 - 1:28 PM
NYCelica
Joined Jul 13, '03
From NY
Sold my Celica....
post Dec 18, 2004 - 1:44 PM
Sev408
Joined Dec 4, '03
QUOTE(coustoe @ Dec 18, 2004 - 1:19 PM)
[right][snapback]223290[/snapback][/right]
well your system can cool only to what your room temperature is at. so mine runs around 68-73 degrees year around so that is as low as it will drop. Basicly water cooling allows you to overclock your PC or video card and keep it running at very cool temps compared to just using fans. Its quieter also.
QUOTE(NYCelica @ Dec 18, 2004 - 1:28 PM)
[right][snapback]223293[/snapback][/right]
hahah, na distilled water and non conductive color dye.
post Dec 18, 2004 - 1:54 PM
Sev408
Joined Dec 4, '03
btw uppity ur system looks nice bro. Have fun with that water cooling, ill be using it the rest of my life.
heres some more pics of my junxs. sorry they are blurry cause my camera hates taking close ups. retarded kodak
yeah i know its kinked on the corner rolleyes.gif i cant find anyway for it not to. it hasnt effected anything cause my temps dont change any my flow is barely changed when i hold it unkinked.
post Dec 18, 2004 - 1:58 PM
Sev408
Joined Dec 4, '03
sorry 1 more post
uppity did you have to cut the screw from your GPU cooler because it was hitting your NB passive cooler. Cause i had to cut mine then bend the last fin outward some so they did not touch.
post Dec 18, 2004 - 4:41 PM
Uppitycracker
Joined Jul 12, '03
From Chatham, Ont
QUOTE(Sev408 @ Dec 18, 2004 - 11:58 AM)
sorry 1 more post
[right][snapback]223305[/snapback][/right]
No actually I didnt, it is pretty close though, it looks like we have similar mobos if not the same. I think its the difference in the video cards, mine sits a little farther forward.
Oh and I overclocked my cpu to 3.01 so far and my vga to 575/575. I have to look up numbers for the vga because it seems ram can be turned up pretty high!
few final shots:
My whole setup
All together and done
Now for my next project, find me a laptop!......Cheap! haha
post Dec 18, 2004 - 10:20 PM
CelicaBuddy
Joined Nov 1, '04
1995 Convertible Celica
2003 Nissan Murano SE
post Dec 19, 2004 - 12:00 AM
Uppitycracker
Joined Jul 12, '03
From Chatham, Ont
QUOTE(CelicaBuddy @ Dec 18, 2004 - 8:20 PM)
[right][snapback]223462[/snapback][/right]
yes...yes I am wink.gif sooo uhhh how you doin??haha girls like geeks right?...sometimes?....never?....dammit!
post Dec 19, 2004 - 12:04 AM
celicarocker
Joined Sep 25, '03
From cranston RI
dude its almost as big as your PC....
post Dec 19, 2004 - 12:10 AM
Uppitycracker
Joined Jul 12, '03
From Chatham, Ont
If by almost you mean half then yes! Its pretty much as small as it can be, you should see some of the huge things people make over at overclockers.com, they use like big wooden boxes and ****, its terrible.
post Dec 19, 2004 - 12:46 AM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
that think got a thermostat haha.... what kind coolant you runnin in that baby?
post Dec 19, 2004 - 12:55 AM
Uppitycracker
Joined Jul 12, '03
From Chatham, Ont
QUOTE(rjbibeau @ Dec 18, 2004 - 10:46 PM)
[right][snapback]223505[/snapback][/right]
Just some prestone 50/50, maybe like 20% in the water. Its pretty debatable whether thats even necessary since people who run straight distilled water clame not to have corrosion or fungal/bacteria culture.
post Dec 19, 2004 - 1:34 AM
creis
Joined Jan 10, '04
From Shoreline, WA
*drool*
That is very nice, VERY nice.
*drool*
the box for the radiator etc is a bit big for my tast but who cares its one fine working system, if your holding steady those temps.
177.1 FPS, 293 AVG, oh how I hate you for that biggrin.gif . what do you get with the HL2 test, I bet its quite a bit lower. mine is to emberising to say (53.5 Nvidea GForce FX 5700 LE OC)
post Dec 19, 2004 - 1:40 AM
CelicaBuddy
Joined Nov 1, '04
QUOTE(Uppitycracker @ Dec 18, 2004 - 9:00 PM)
[right][snapback]223482[/snapback][/right]
LOL
Woo! biggrin.gif some girls do go the geek my friend... I guess its for the smarts LOL but hey its all good smile.gif
This post has been edited by CelicaBuddy: Dec 19, 2004 - 1:43 AM
Lo-Fi Version Time is now: November 28th, 2024 - 6:58 PM
