FS: Insturment Gauge Cluster, Km/h |
Dec 29, 2004 - 2:33 PM |
Enthusiast Joined Feb 20, '04 From Washington Currently Offline Reputation: 0 (0%) |
Hey guys and gals,
I have a brand new KM/Hr intrument guage cluster for sale. Everything included, needles, bulbs, plastic clear glass, etc. Please either post on the message board or PM for price info. Thanks! -------------------- |
Dec 29, 2004 - 3:43 PM |
you need to tell engine and tranny cause they are different
Dec 29, 2004 - 4:59 PM |
Aren't all the USDM clusters the same?
Dec 29, 2004 - 5:34 PM |
Enthusiast Joined Oct 4, '04 Currently Offline Reputation: 0 (0%) |
QUOTE(Coomer @ Dec 29, 2004 - 9:59 PM) Aren't all the USDM clusters the same? [right][snapback]227902[/snapback][/right] Is it even USDM? Being in KPH and all. |
Dec 29, 2004 - 5:43 PM |
QUOTE(946thGenGT @ Dec 29, 2004 - 2:34 PM) QUOTE(Coomer @ Dec 29, 2004 - 9:59 PM) Aren't all the USDM clusters the same? [right][snapback]227902[/snapback][/right] Is it even USDM? Being in KPH and all. [right][snapback]227922[/snapback][/right] Doh! I don't even know what I was thinking. It must not be. -------------------- New Toyota project coming soon...
Dec 29, 2004 - 5:45 PM |
Enthusiast Joined Oct 28, '02 From Europe, Lithuania Currently Offline Reputation: 8 (100%) |
Auto and Manual are different, GT and ST may be different too, 94-95 and 96-99 will be different to cuz of OBD I and OBD II.
But still it can be used. QUOTE(Coomer @ Dec 29, 2004 - 2:59 PM) Aren't all the USDM clusters the same? [right][snapback]227902[/snapback][/right] -------------------- Ex celica owner - just a guy from other side of the pond...
Dec 29, 2004 - 8:03 PM |
how can it still be used i probably will have to use this one
Dec 30, 2004 - 3:27 AM |
Simply. It may not work propertly if the Auto cluster is used inManula car and vise-versa. But if its from OBD II and you gonna us it in OBD I, (or otherwise) the difference will be only in warning lights, the wiring MIGHT be different, so you may get all the warning lights mixed up (like instead of fuel light you will get ENGINE CHECK light, and fuel light will act as engine check )
thats it, everything else should work. QUOTE(playr158 @ Dec 29, 2004 - 6:03 PM) how can it still be used i probably will have to use this one [right][snapback]227984[/snapback][/right] -------------------- Ex celica owner - just a guy from other side of the pond...
Dec 30, 2004 - 11:55 AM |
mmk
well i'll see if i can do a return policy do the MPH have MPH in a lil numberS? |
Dec 31, 2004 - 6:53 AM |
no
QUOTE(playr158 @ Dec 30, 2004 - 9:55 AM) mmk well i'll see if i can do a return policy do the MPH have MPH in a lil numberS? [right][snapback]228215[/snapback][/right] -------------------- Ex celica owner - just a guy from other side of the pond...
Dec 31, 2004 - 3:16 PM |
Enthusiast Joined Apr 15, '03 From San Jose, CA, USA Currently Offline Reputation: 1 (100%) |
Guys the Speedo, and Tach will work in our guage clusters, or atleast im pretty sure they would.... These pieces screw off off the guage cluster, and would then need to be reatached to your guage cluster.
PS, what is the cluster from? Like where is the Redline on the Tach? |
Dec 31, 2004 - 3:21 PM |
a perfect example of this is that the TRD speedometer fit in all (by their specs) St20* models.
Dec 31, 2004 - 7:46 PM |
Enthusiast Joined Aug 29, '02 From Franklin/Nashville, TN Currently Offline Reputation: 16 (100%) |
^ my instrument cluster. It's the stock 94 Celica ST main cluster, with i have NO idea what year JDM/Euro tachometer and KPH speedometer. the entire tach/speedo gauge comes by undoing about 4 screws each on the back of the cluster, and the new one goes right in, and everything is translated properly, so the gauges are still accurate, only in a different measurement(for the speedo). . -John- -------------------- |
Lo-Fi Version | Time is now: November 23rd, 2024 - 3:54 PM |
