> Engine is choking...
post Jan 2, 2005 - 2:33 PM
liquor
Joined Jan 31, '03
From Montreal, Canada
Hey ive been out for a couple of days during the holidays and my ride been sitting in the driveway all that time... it started no problem and i let it run at idle for couple of minutes before taking off but the engine was choking whenever i hit the gas in 2nd or above and when going back to idle (had to rev up alot so it doesnt stop). After 15 minutes everyhting go back to normal. This happen everytime i dont use my car for 3-4 days or more.
It must have something to do with humidity... any ideas of which parts/wires might cause this?
post Jan 3, 2005 - 3:31 AM
Newbie
Joined Nov 3, '04
From Colorado
Tune up?
post Jan 16, 2005 - 7:12 PM
liquor
Joined Jan 31, '03
Well what do you mean by tune up? I had spark plugs/wires/battery changed 2 years ago and all fluids are fine
post Jan 16, 2005 - 8:05 PM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
It could be a lot of things, and weather really isnt an reason for any problem for a car. I would say do a tune up. spark plugs oil filter, air filter, GAS FILTER, then plugs cap rotor. Then if that dosnt help it, i would say try and check for a vacume leak. It there is no vac leak, check ur fuel pump and injectors. It could be other stuff but that should give u an easy start to checking up and getting it runnnign smothly.
post Jan 17, 2005 - 9:44 PM
spunky393
Joined Apr 22, '04
From illinois
focus on the cap and rotor. Sometimes, extreme weather could "shock" the material the cap is made out of and crack it.
The most important lesson I learned from Karate-Dō Kyōshan“You can not be what you do not believe you are”
post Jan 18, 2005 - 8:50 PM
navyfc
Joined Jan 18, '05
From San Diego
QUOTE(spunky393 @ Jan 17, 2005 - 9:44 PM)
[right][snapback]234899[/snapback][/right]
Mine is doing about the same thing. It will start right up, and then it will idle verry low, and act like it's gonna cut out, but it never does, it just sits at a super low idle till I rev it up a few good times and then no problems untill it sits for a few days.
post Jan 22, 2005 - 12:55 PM
maikl
Joined Mar 3, '03
From cyprus
make your car a very good service and i thing everythig will go back to normal! wink.gif
post Jan 22, 2005 - 6:02 PM
Bigmeanbulldog55
Joined Jun 1, '03
From WV
I'm having the same problem, exept mine does it every time I start it up if it's been sitting only a few hours. I think weather can be the primary cause of some problems with cars, how could you say it doesn't effect?
This post has been edited by Bigmeanbulldog55: Jan 22, 2005 - 6:03 PM
Live Free, Be Happy
post Jan 23, 2005 - 4:53 PM
TRD6GC
Joined Nov 17, '03
I have a similar problem as well. My car hesitates, like its not getting enough/too much gas. I changed spark plugs, wires, gas filter, cap and rotor, fixed a couple vacuum lines, and messed with the throttle and idler to get everything just right, still does it though. Any suggestions?
post Jan 25, 2005 - 9:09 PM
chosen1
Joined Nov 20, '02
From Chicago to Boston and back to Chicago
I'm having the exact same problem but my car actually cuts off. It first happened when I was driving my car away from getting a tune up (not even 1 minute) and it happens if I don't let my car warm up for at least 10-15 mins every morning before driving it. If it's not warm, it'll cut off and act like it doesn't want to start again. After a couple of seconds it'll start and I'll have to rev it up for it not to cut off. The RPM's are very low also and it dips all the way down (almost cutting off) when I stop revving it up.
post Jan 25, 2005 - 9:48 PM
navyfc
Joined Jan 18, '05
From San Diego
Mine didn't start till I put the short ram intake on. Maybe air/fule mixture makes sense. I fund a HOW TO reset your air/fule mixture article on this site. I am going to try it. I am out to sea right now(NAVY, go figure) and can't do it till I get back, and then I have to wait till I get my car back from the body shop any ways, so if one of yall want to try it, let me know if that does the trick. It can't hurt anything to rest it. Here is the thread
http://www.6gc.net/index.php?action=howto&itu=33
post Feb 8, 2005 - 10:12 AM
navyfc
Joined Jan 18, '05
From San Diego
bump
post Feb 8, 2005 - 11:35 AM
Justin
Joined Dec 13, '03
From Alabama
I remember a while back my car wouldn't idle well (around 100 rpms) and I reset the ECU and everything went back to normal.
Lo-Fi Version Time is now: February 22nd, 2025 - 11:22 AM
