> Best Make of tire!!!, Toyo, Kumho, Pirelli, Yoko???
post Jan 3, 2005 - 12:24 PM
Guest_DJMC_Celica_*
Who do you think is the best Tire Manufacturer? I need new tires, and i keep getting mixed reviews from different people on the size and type to get. Any suggestions?
my size is 215/35w/r18
Thanks
post Jan 3, 2005 - 6:45 PM
aahh you said 18 amazing you didn't claim 19 and 1/2 mwahahahaha
bfgoodrich, toyo
post Jan 3, 2005 - 7:19 PM
Guest_DJMC_Celica_*
In order to stop scrathing of my lip should i go with 35 or 40?
Drocay
Joined Oct 3, '02
From Va Team 6gc
Toyo, Yoko, then BFgoodrich
Team 6gc 2005
post Jan 3, 2005 - 8:23 PM
boosted_K2
Joined Aug 30, '02
From Michigan
for on the budget kumhos are great
No but I don't buy it
Cause I'm...
post Jan 3, 2005 - 8:25 PM
boosted_K2
Joined Aug 30, '02
From Michigan
QUOTE(DJMC_Celica @ Jan 3, 2005 - 7:19 PM)
[right][snapback]229555[/snapback][/right]
that would probably be best fixed by not parking in obsquire off-road or otherwise grassy regions wink.gif
Cause I'm...
post Jan 3, 2005 - 11:15 PM
Guest_DJMC_Celica_*
No offense but i could use a better response than that! Otherwise i could park it in your front yard! hehehe
post Jan 3, 2005 - 11:35 PM
boosted_K2
Joined Aug 30, '02
From Michigan
ok better response, quit parking so close to the curb and keep a higher pressure in your tires. if your getting them knicked and scraped from debris, your SOL tire size isnt going to do anything.
Cause I'm...
post Jan 4, 2005 - 2:40 AM
khomos suck
post Jan 4, 2005 - 9:00 AM
Guest_DJMC_Celica_*
QUOTE(boosted_K2 @ Jan 3, 2005 - 11:35 PM)
[right][snapback]229628[/snapback][/right]
Righttttt........anyways, i just need to know if i should go with a 35 or 40? anyone have any better suggestions?!!! hehehe
post Jan 4, 2005 - 3:33 PM
SlowCelica94
Joined Sep 28, '03
From Bloomington, IN
Toyo best? Never heard that one. Everyone is going to be bi-ist (sp) and select their brand. But Pirelli, BFgoodridge, yoko is all real nice. I stay away from michellen, cooper, zeon, all offbrand ****, continental and some others i cant think of
92 Civic hatch B16 - Sold
10th anniv RX-7 - RIP
post Jan 4, 2005 - 3:50 PM
Guest_DJMC_Celica_*
The only reason im nervous about yoko, is cause my uncle purchased the perada spec 2s for his car, and they were off, the tires were messed. They ordered him new ones and 2 tires were screwed up, so he got Toyo, and he loves them he got the TS1s He said it has an awesome ride... SO BACK TO MY ORIGINAL QUESTION....40 or 35 for my wheels?
post Jan 4, 2005 - 4:10 PM
nik
Joined Sep 30, '02
go 225 40 18 or 235 35 18 what is the width of your rim?
This post has been edited by nik: Jan 4, 2005 - 4:11 PM
post Jan 4, 2005 - 4:23 PM
Guest_DJMC_Celica_*
To be quite honest, im not sure the width, but would the 225 235 fit in my wheel well?
post Jan 4, 2005 - 5:00 PM
Pirelli is the overall better tire - theres a reason they're stock on BMWs and Ferraris.
35 is an awfully low pro tire - i have 35's and hate them.
post Jan 4, 2005 - 5:22 PM
Guest_DJMC_Celica_*
So 40s?
post Jan 4, 2005 - 5:45 PM
QUOTE(DJMC_Celica @ Jan 4, 2005 - 2:22 PM)
So 40s?
[right][snapback]229924[/snapback][/right]
It's a choice you have to make. Speedometer off and possible rubbing issues or a harsher ride and greater chance of rim damage.
post Jan 4, 2005 - 5:57 PM
Guest_DJMC_Celica_*
with 40s? not 35s?
post Jan 4, 2005 - 6:05 PM
OK, you should have 215/35/18 sized tires if you want your speedometer to reflect the actual speed that you're going. With this size tire, you should not rub either, assuming you have the correct offset. However, your ride will be worse and you'll have more chances of rim damage than you would with a 40-series tire.
But with the 40-series tire, you might rub...Natalie has 225/40/18-sized tires and she rubs due to her offset. When I had 225/40/18-sized tires on my 18s on my car, I didn't rub, I'm assuming because my offset was different. Also, your speedometer will be off with a 40-series tire. When it says you're going 60 mph, you'll actually be going 63 mph with a 225/40/18 tire.
post Jan 4, 2005 - 6:10 PM
Guest_DJMC_Celica_*
what about 215/40/18? Well i am thinking the 40. What do you mean by Offset?
Lo-Fi Version Time is now: January 10th, 2025 - 5:47 AM
