> Anyone Have "Shady Mechanic Work" On Their Celi?
post Jan 12, 2005 - 5:10 PM
I'm just curious as to if anyone's car has or had "Shady Mechanic Work" on their car when they got it. You know...stuff just done to get it done, but not done right.
My purple Celica that I'm parting out definitely fits this. Just the other day I pulled off the door panels so that I could pull off the mirrors. When I pulled off the passenger side door panel, I found a 8" no-name speaker(Remember, this is a non-power options car with 6.5" speakers from the factory) screwed directly into the metal with wood screws. And the other side of the car has the stock 6.5" speaker in the plastic mounting bracket.
When I pulled out the Sony cd player(It was broken, but that should be assumed with Sony.), the stock stereo harness was hacked off and the CD player's wires were just connected directly to the stock wires. Soldered? Nope. Crimped? Nope. Twisted and taped with masking tape? Yes.
When I was pulling out the glove box, I wondered why it wasn't coming out after removing all the factory screws. Turns out the previous owner put two extra sheetmetal screws in the side of it closest to the door.
Also, one of the factory bolts on the passenger seat was replaced with a drilled hole in the rail, a sheetmetal screw, and a big washer. There's an old, old, old siren in the engine bay and a little LED light under the dimmer switch, but the wires just connect to each other with a wire crimp. confused.gif
I would be so mad if I'd bought a nice car and found stuff like this. But the purple Celi is only a parts car, so it's all good. Still, the previous owner/bodyshop/whoever should be locked up for Celica abuse(and painting the car purple.) tongue.gif
My yellow Celica had the stereo harness hacked off by my friend before I knew anything and let him install my stereo. Since then though, I found a junkyard Toyota, cut the stereo harness, and soldered it back on, and now my stereo is installed correctly. My mechanic lost one of my upper radiator brackets, so we had to make a custom one that was ugly, but now it's replaced with one from the purple Celica.
Anyone else experienced this with their Celica?
This post has been edited by Coomer: Jan 13, 2005 - 7:17 PM
post Jan 12, 2005 - 5:16 PM
Consynx
Joined Dec 25, '02
From Pittsburgh/Clairton, PA
aftermarket sunroof :\
post Jan 12, 2005 - 5:23 PM
thedevilmaycrie
Joined Nov 15, '02
From Vidor, TX
on my celica ummm no however the rule in texas is "cant duck(tape) it f@ck it"
-DMC
post Jan 12, 2005 - 5:43 PM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
umm that would be doing stuff to my car. Every time i do somthing i loose a screw, then can find one top put back in, but once i find a celica at the junk yard it will be all good, but thats only like usless interior screwes any ways.
My thought is, if you end up with extra parts and it still works, you've just made it moree efficient
post Jan 12, 2005 - 6:29 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
my story beats this one. i was replacing a window regulator in my dad's 94 camry cuz the window when he bought it wouldn't go down and over time it fell a lil and left a gap. when i pulled the panel off i notice a stick chillin in the back and some speaker wire was holding up the track. soon as i ripped the stick out the window fell like 6" i just about cracked up. so then i go and show my dad and he got a kick out of it. but the regulator is in and works fine.
post Jan 12, 2005 - 6:36 PM
SlowCelica94
Joined Sep 28, '03
From Bloomington, IN
Zip ties are your friend. No shame in ghetto riggin if it works
92 Civic hatch B16 - Sold
10th anniv RX-7 - RIP
post Jan 12, 2005 - 6:50 PM
ghostdog
From ny to philly
my head unit was ghetto installed frown.gif didn't know any better at the time. and I got zip ties holding the fuel filter in place cause I lost the screw. but yeah my car deserves better, eventually I'll get around to it
post Jan 12, 2005 - 10:21 PM
S_C_M
Joined Mar 2, '04
From Louisiana, USA
I hacked up my stock door speakers so that I could use them as brackets for some 6.5" Kenwoods I put in their place. I cut out my cigarette lighter so that I could put my AFC in its former location...
Is it ghetto/redneck that my Rev/Speed meter is mounted over the (disconnected) stock clock? I have a clock on my CD player, so it was useless to me. Oh, I also have no rear seats or trunk interior. That in and of itself is pretty bad, but I have come to prefer it that way.
post Jan 12, 2005 - 10:26 PM
Mynzeyes
From Franklin/Nashville, TN
i think the title of this thread is quite derogatory...just FYI...
AIM==Mynzeyes
post Jan 12, 2005 - 11:48 PM
Sh0gunkid8721
Joined Feb 22, '03
i had zipties holding up my front liscence plate, but thats been fixed.
post Jan 13, 2005 - 4:02 AM
madmods
Joined Mar 19, '04
From Scottsdale, Az
Man, you should have seen my convertible frame. it was cracked in half, and looks like somebody used steel wire to sew it together. No lie. it was sewn with steel wire through the frame. I got damm lucky finding one on ebay.
post Jan 13, 2005 - 4:29 AM
Akimbo
Joined Jun 30, '03
From O-town, FL
Exgirlfriend and I (mostly her) put a mesh grill on my car. It's tied together with zipties. You can find zipties and 3M double sided tape everywhere on my car. Gotta give her credit on the grill. It's fackin neat. And still there. She was a crafty one.
- Ryan
aim: rkgreen04
post Jan 13, 2005 - 11:18 AM
shid
Joined Jan 8, '04
From LA
Zip ties are not redneck engineering.
post Jan 13, 2005 - 12:42 PM
SlowCelica94
Joined Sep 28, '03
QUOTE(Mynzeyes @ Jan 13, 2005 - 3:26 AM)
[right][snapback]233059[/snapback][/right]
Well, do u wanna know what I usually call "redneck work?"
post Jan 13, 2005 - 4:22 PM
jwells
Joined Jan 3, '04
From knoxville, tn
"Somebody give me a fire...so I can burn this city down." - Widespread Panic
post Jan 13, 2005 - 5:52 PM
Mynzeyes
QUOTE(jwells @ Jan 13, 2005 - 3:22 PM)
[right][snapback]233381[/snapback][/right]
no, it's just the same as calling it something else, and i wonder why it's ok to talk down about one stereotype of person rather than another. it's perfect logic.
perhaps "shade tree mechanictry" would be a better label? wink.gif.
and slowcelica, no, i don't care what you call "redneck work"...
-John-
This post has been edited by Mynzeyes: Jan 13, 2005 - 5:55 PM
AIM==Mynzeyes
post Jan 14, 2005 - 2:14 PM
Nemises
Joined May 6, '04
From antioch CA
Check this out when i first got my kit put on I went to a shop that swore they could do the work. (Colcraft Inc Lynn Ma dont go their) So I had my car in their shop 6 months and at first they told me two weeks but thats a whole other story. Here are the things wrong with my ride when I got it back.
1. broken glass still in the car
2. I turn on my rear whipper and they put it on wrong the thing flipped up on top of my wing
3. The sun was in my eyes I flip down my remote start atenna comes down and hit me in the head. They just tucked it under the visor
4. No heat
5. no ac
6 dripes in paint front and rear
7. inch and a half gap between kit and headlights and it wasnt even cut straight it looked like someone atually chewed on the edge. no lie
8. stole my fire extinguisher
9. alignment way off.
10.no parking light bulbs
11. the worst molding job i ever seen in my life.Looked like they just used calking to me
12. dude tryed to charge me double and said i should have known the price he quoted me would be more 2xs more.
After that experience I taught myself how to do body work.And basically re did my whole car the folowing summer.
post Jan 14, 2005 - 2:20 PM
Sev408
Joined Dec 4, '03
how about during the installation of my manual trans I ended up with 4 extra screws from the interior, i went over everywhole i could think of and tehy are all covered. I am so confused i still have teh screws.
user posted image hows it taste motha f*cka
post Jan 14, 2005 - 8:06 PM
Jdog1385
Joined Apr 14, '03
From Long Island, N.Y.
some scratches on the exterior that were covered up. fixed it though
Lo-Fi Version Time is now: November 24th, 2024 - 4:26 PM
