> Turbo Lag and pipe size?, size matter?
post Mar 4, 2005 - 5:13 AM
urbandork
Joined Jul 16, '04
From Los Angeles
Does pipe from the turbo to the intercooler and finally to the TB affect how much turbo lag. What would be the optimal size pipe for a 5sfte with a ct26 twin entry running about 8 or 9 psi?
I was thinking 2 would 2.5 inch be to big?
also is it better to use alluminum or mild steel? I figure alu cus its lighter, but how does it conduct heat?
This post has been edited by urbandork: Mar 4, 2005 - 5:28 AM
post Mar 4, 2005 - 8:29 AM
your gonna wanna stay under 2.5....im planning 2 1/4.. i think itchy was using 2"..dont know if he still is.. wink.gif
post Mar 4, 2005 - 8:35 AM
Distance has alot to do with lag, but the ct26 is fast spoolin its going to be pretty low no matter what, its not much of a concern with small turbos.
post Mar 4, 2005 - 10:59 AM
sphinx
Joined Apr 10, '03
From South Central Los Angeles
QUOTE(Supersprynt @ Mar 4, 2005 - 5:35 AM)
[right][snapback]253134[/snapback][/right]
that's true. But i wouls still stick with under 2.5 like presure said. Mine is 2.25 (2 1/4)
post Mar 4, 2005 - 2:45 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
yeah i got 2" and the shorte path the better.
post Mar 4, 2005 - 3:09 PM
urbandork
Joined Jul 16, '04
From Los Angeles
About path would less 90 degree bends be better or do bends not matter much just so long as its not an s shape (asking the air to turn back on its self)
post Mar 4, 2005 - 3:26 PM
the less bends the better.
post Mar 4, 2005 - 3:55 PM
urbandork
Joined Jul 16, '04
From Los Angeles
QUOTE(Supersprynt @ Mar 4, 2005 - 8:26 PM)
[right][snapback]253263[/snapback][/right]
would the less sharp bends i.e. 90 degree bends help too? basically a straighter flow
post Mar 4, 2005 - 3:57 PM
well yeah thats what i mean, the less bends, the less of a bend, the better.
Air always flows faster when everything is straight.
post Mar 4, 2005 - 4:17 PM
urbandork
Joined Jul 16, '04
From Los Angeles
coolios
post Mar 4, 2005 - 7:57 PM
i have 2.25 on mine....anything 2-2.25 is perfect for our cars and power goals
post Mar 4, 2005 - 8:42 PM
urbandork
Joined Jul 16, '04
From Los Angeles
what about material. alluminum is nice but is mild steel ok?
post Mar 4, 2005 - 9:24 PM
sphinx
Joined Apr 10, '03
they're both ok, the only difference is that you have less weight with alluminum
Lo-Fi Version Time is now: February 22nd, 2025 - 8:08 AM
