![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jul 16, '04 From Los Angeles Currently Offline Reputation: 8 (100%) ![]() |
If i get a larger fuel pump and larger injectors will i need to get a fuel presure regulator or n e thing else? I figured that since its a larger out put pump it might need some other things to suport it.
thanks. |
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 17, '04 From Illinois Currently Offline Reputation: 0 (0%) ![]() |
You will need something to control the fuel. Preferably a standalone EMS but a fuel controller will work. A regulator may be needed for high horsepower applications or if you wanted to bump up your pressure to maximize power on injectors that were not big enough. There are limits to running higher pressures though.
-------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
so i cant just run larger injectors and a larger fuel pump?
QUOTE(urbandork @ Mar 10, 2005 - 12:26 PM) so i cant just run larger injectors and a larger fuel pump? [right][snapback]255646[/snapback][/right] Re-read my first post. You can run just a larger pump. However, you CANNOT run larger injectors without something to control them - at least without it running poorly from an overly rich condition. There are a few guys on the MR2 board that claim to run 550's on the stock 3s ECU with no problems but they are definitely the exception. Running excessively rich causes problems over the long run. The stock ECU has been programmed to run stock injectors. It is set up to open the injector for a certain duration under various RPM, temperature, and load conditions. If you use larger injectors and a stock ECU, you will get too much fuel. The whole point of running larger injectors is to maximize performance. It just doesn't make sense why someone would want to put larger injectors in and then not utilize them properly by tuning the A/F ratio correctly. -------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
humm. well would it made a diffrence if im boosting and using an msd btm? Ive been reading at it seems that when running a 5sfte larger injectors and a larger fuel pump so it wont run lean. But what i havent seen are ppl talking about the a/f mixutre and how to change it?
This post has been edited by urbandork: Mar 11, 2005 - 2:11 AM |
Enthusiast ![]() ![]() Joined Nov 3, '04 From Colorado Currently Offline Reputation: 0 (0%) ![]() |
I thought the 3rd generation of 3SGTE's used the 550cc injectors stock?
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 16, '03 From Bay area Currently Offline Reputation: 0 (0%) ![]() |
it would be best to control the fuel mixture. because the stock fuel mixture map is designed for no boost. So even with the upgraded fuel pump and injectors. The ecu will still dump fuel where it is not needed, and lean out where it needs fuel.
People talk about changing fuel mixture all the time with the apexi fuel controler, and greddy emanagment. |
QUOTE(Newbie @ Mar 11, 2005 - 2:21 AM) I thought the 3rd generation of 3SGTE's used the 550cc injectors stock? [right][snapback]255983[/snapback][/right] Actually 540's but close enough. But the 2nd gens come with 440's so thats what I meant by "upgrading" to 550's. This post has been edited by jgreening: Mar 11, 2005 - 8:57 AM -------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
if you have a 3sgte and want to upgrade to 550s, you would need an fpr and some type of piggy back ecu controller to tune the car with.
a btm works by retarding the timing of the car based on boost. you dont need to do that on the 3sgte because its a facotry turbo car. -------------------- 15PSI - 30MPG - Megasquirt Tuned
so on a 5sfte set up what do i need?
225 lph fuel pump 330cc injectors BTM to retard timing and a piggy back ecu ???? i |
Lo-Fi Version | Time is now: February 20th, 2025 - 6:03 AM |
