quick help on motor mount, 5th gen |
Mar 12, 2005 - 1:57 PM |
Enthusiast Joined May 19, '04 From The Coast, New Hampshire Currently Offline Reputation: 0 (0%) |
my front motor mount is busted. toyota wants 125 plus shipping and it wouldnt be here for a week, im going to go to the wrecking yard today and i know they have 5th gen gt's, but not sure if htey have 6th gens, if they do have a 5th gen does any one know if the 5th gen motor mounts are similar or the same as the 6th gen?
This post has been edited by redtcel: Mar 12, 2005 - 1:58 PM |
Mar 12, 2005 - 5:07 PM |
Enthusiast Joined Sep 12, '03 From Portland , Oregon , United States Currently Offline Reputation: -1 (33%) |
Yep, Im using 5th gen 5s mounts.
DTE -------------------- I am a thief.
do not buy anything from me. |
Mar 12, 2005 - 5:19 PM |
k then i have a question, i just got a 5th gen 5s mount for the front from napa, and they look similar but they dont match up just right, i havent taken the old one off yet because i dont want to go through the trouble just for it not to wrok so here is a picture of what i am looking at.
the new one is flat on the bottom where the old one looks like it has a "two step" bottom. if that made any sence what so ever. |
Mar 13, 2005 - 6:34 PM |
Enthusiast Joined Jun 1, '03 From WV Currently Offline Reputation: 2 (100%) |
What mount you need? I've got one for sale.
Mar 13, 2005 - 10:13 PM |
QUOTE(Bigmeanbulldog55 @ Mar 13, 2005 - 11:34 PM) What mount you need? I've got one for sale. [right][snapback]256806[/snapback][/right] 5th ggen turned out to be wrong size, the bolt patterns was off, and the center hole for the connection of th emount to the bracket was too larger of a diameter, i need the front motor mount, when you are looking in the motor the one that is right behind the radiator |
Mar 14, 2005 - 4:14 PM |
QUOTE(redtcel @ Mar 13, 2005 - 10:13 PM) QUOTE(Bigmeanbulldog55 @ Mar 13, 2005 - 11:34 PM) What mount you need? I've got one for sale. [right][snapback]256806[/snapback][/right] 5th ggen turned out to be wrong size, the bolt patterns was off, and the center hole for the connection of th emount to the bracket was too larger of a diameter, i need the front motor mount, when you are looking in the motor the one that is right behind the radiator [right][snapback]256881[/snapback][/right] Sorry, I've got the rear mount. The one that went you look at the motor it's on the right. I had to buy that mount that you're looking for. There's a way to make your own urithane bushings for the mount. Take what you've got, and cut out the rubber part. Lay it on a flat surface. Pore liquid urithane into the hollowed out mount. It should cost less to do than buying a regular mount, and it's urithane. -------------------- Live Free, Be Happy
Lo-Fi Version | Time is now: December 1st, 2024 - 6:02 AM |
