> Installing my Premier 770, How do I?
post Mar 15, 2005 - 11:05 AM
JoKeRkId613
Joined Apr 25, '03
From Miami, FL
I just got a Pioneer Premier DEH-P770MP(Very Nice)
There's a bunch of colorful wires with tags on it. Battery, Antenna, etc.
Are they colormatched to the factory wires? Because I have the tags on the new wires but I don't know what wires to hook them up to. And what do I use to make the connection between the two wires. I've seen little caps used to connect the cables but im not sure what theyre called. thanks.
post Mar 15, 2005 - 2:25 PM
you should use a harness adapter. It's like $5 at Walmart or autozone. OIt will make everything much easier. Also, there is an install how-to here pdf format download from this site install doctor
post Mar 15, 2005 - 10:37 PM
JoKeRkId613
Joined Apr 25, '03
From Miami, FL
Thanks a lot bro. That guide is awesome. I'm going to go buy that harness adapter to make it easier. Should be just as good as directly connecting it. Thanks again, man!
post Mar 15, 2005 - 11:05 PM
RbrtNdrws
Joined Jul 8, '04
From Durham, NC
QUOTE(JoKeRkId613 @ Mar 16, 2005 - 3:37 AM)
[right][snapback]257841[/snapback][/right]
i assume that you have the 6 speakers? if you have the 8 speakers (3 on each side in front) you will need the metra amp integration harness to get the headunit to work with the stock amps...
-Rob
post Mar 16, 2005 - 12:43 AM
he has a 94 ST, my 95 ST only has 4 speakers.
post Dec 26, 2005 - 4:34 PM
azian_advanced
Joined Apr 18, '05
From Calgary
QUOTE(RbrtNdrws @ Mar 15, 2005 - 10:05 PM) [snapback]257850[/snapback]
-Rob
where can i buy this kind of harness? (i have the 8 speaker system with dual factory amplifiers.)
i want to use another factory Toyota cd stereo in place of my current one and still use the stock amps so i won't have to meddle with rewiring each speaker to new aftermarket amplifiers.
post Dec 30, 2005 - 1:45 AM
Tech9ine
Joined Jun 28, '05
From MB, Canada
I've got a Premier 4700mp. very similar deck, i got the harness at Brian Reimer audio in winnipeg. Best buy has it too.
post Jan 12, 2006 - 4:04 PM
downshft
Joined Dec 12, '04
From GTA, Ontario
I'm having a devil of a time trying to unplug a connection that bypasses the amp so I can connect my rear speakers. The space is so small under the amplifier box and I have to try and 'pull' the wires 'away' from me to get the white connector off. I can't see any other way of getting to this connector without taking out my front seat(s) All I want to do is remove the panel next to the accelerator. I even tried prying the carpet to get my hand in.
I hate my car now.
*edit*... what I'm talking about is the Installation Note: section on page 4.
This post has been edited by downshft: Jan 12, 2006 - 4:06 PM
post Oct 16, 2006 - 10:26 PM
bdweber3
Joined Sep 12, '06
From Telford PA
i have a six speaker system and i put in a harness by bypassing the stock amp but now only 4 speekers and my tweeters dont work but is there a harness made for 6 speakers systems? if there is please let me know. im very interested in getting one.
post Jan 12, 2007 - 6:57 PM
gabyz
Joined Jan 11, '07
From Fort Lauderdale, FL
QUOTE(downshft @ Jan 12, 2006 - 9:04 PM) [snapback]377700[/snapback]
I hate my car now.
hey downshift, I am having the same problem to. I'm trying to put in a new basic cd player 1 din system in my 6g. But I cant get to that blue connection under the amp! Does anyone know
Question: Since the new player will have its own built in amp, do I need to keep the orignal one down there?
3 post spoiler for sale: Click here
post Feb 8, 2007 - 1:00 PM
Manny
Joined Feb 8, '07
From Oakland, Ca USA
Does your new CD player have RCA pre-amp connectors on it? If so, just get an aftermarket Toyota/Lexus factory amp integration harness. That will make the installation go a lot easier, since it will allow you to plug your new cd player into the harness from the back of the stock stereo, without having to mess with the amp.
I had the same issue, and I had to remove the kick panels to get to the amp wiring, so i got an integration harness and I was also able to take advantage of all 8 speakers in my car.
Hope this helps..
-M-
-M-
post Feb 9, 2007 - 6:20 PM
laff09
Joined Jul 28, '06
From Delaware
a little off-topic, but your profile says your using Bosch platinum plugs ... I thought they were detrimental to our engines, something about the spark being too powerful? can anyone confirm/deny this? Not trying to step on your toes or anything, was just curious
post Jun 26, 2007 - 2:18 PM
celicat
Joined Jun 26, '07
From MD
I just bought a sony chameleon headunit from a friend and then i went to best buy to buy the wiring harness. I got the one for toyotas 1987+, I drive a 95 gt, but when i went to plug it into my factory wires it doesn't fit at all.
I'm wondering did I buy the wrong harness or am I just doing something wrong? The wiring harness came with one big plug and one small plug but there is only one factory wire.
Any insight would be very helpful
post Jun 26, 2007 - 2:25 PM
94celigts
Joined Jun 13, '07
From Whitby, ON, CAN
i removed the stock amps in my 8 speaker system and found the proper plug for my adapter from Futureshop. I just spliced the 3.5 and the door sub's together, so now they are running on the same channel it works, but im sure separated they would sound a bit better
RbrtNdrws
Joined Jul 8, '04
From Durham, NC
Wow this topic is oooollld. Do you have the double din stereo or single ?
post Dec 26, 2007 - 11:42 PM
tjblacrosse
Joined Oct 25, '07
From Eagan, MN
nice system
This post has been edited by tjblacrosse: Jan 1, 2008 - 1:24 PM
post Jan 30, 2011 - 5:48 PM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
btw, would it be possible to add an aux cable to a stock 99 Celica GT Head Unit. I just don't want to be carrying around a whole bunch of cd's in the car as I would prefer to have the Ipod connected
post Jan 30, 2011 - 6:07 PM
mkernz22
Joined May 10, '10
From MA
QUOTE (BonzaiCelica @ Jan 30, 2011 - 5:48 PM) *
highly doubt it.
post Jan 30, 2011 - 6:12 PM
richee3
Joined Jun 29, '08
From Denver
For a '98-99 Celica with an OEM radio, you can actually buy a box from GROM Audio that does iPod integration. I can't confirm that the radio was the same for the '94-97 model though. The box plugs directly into the back of the CD player and then you can put your iPod anywhere in the car- in your hand, in your glovebox, anywhere the cable will reach- and you can control the iPod using the head unit. Just the same as if it was a CD. I have one in my IS 300 and it's simply brilliant. Clicky.
Most (if not all) aftermarket stereos will support iPods. As far as using the factory stereo and making an auxiliary port, it's very possible. There's a writeup somewhere around 6gc, and there are plenty of Toyota forums around where people have done their own aux port. The concept is the same for our radio.
Edit: Found the 6gc writeup. Clicky.
This post has been edited by richee3: Jan 30, 2011 - 6:21 PM
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Feb 2, 2011 - 3:10 AM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
Hey speaking of the 6 speaker system, do you guys know how the factory tweeters are wired in? do they run in parallel with the door speakers or is there a hidden crossover?
Mike W
269awhp / 273ft-lbs
Lo-Fi Version Time is now: November 23rd, 2024 - 9:26 AM
