![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 25, '04 From Wisconsin Currently Offline Reputation: 0 (0%) ![]() |
Well time for another computer problem that chances are no one can help me with.
First, let me start off that I bought the first season of Beast Wars: Transformers today. And oh boy its great. Go Dinobot. Aside from that. I also bought a longer S-video cable, a 12 footer. Connected up the puter and the good ol 27" Apex (cheapie) TV. I finally played hide and seek with my Windows standard settings and got the SOB to run clone mode. Ended up installing my ATI standard drivers. However, (the big but!!!) I only get black and white. No color on the TV. The computer looks great, tv is in black and white. I then gave'r the good ol Google search. I only came to 105,000 responses, all of which are stupid and didn't give me any info. ATI 128MB 9200SE Windows XP Brand spankn' new S-video cable, gold series high tech (good) Apex 27" Cheapie TV standard settings. I get video - no color and I just did a SCAN on the TV to see if that worked - nope ANY CLUE PLEASE HELP ME! -Ti |
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 16, '03 From Bay area Currently Offline Reputation: 0 (0%) ![]() |
try wiggling the s video cable. it could be the cable is so long that it is bending where it plugs into the TV.
try unpluging it and plug it in and holding it. |
QUOTE(Hanyo @ Mar 28, 2005 - 10:13 PM) try wiggling the s video cable. it could be the cable is so long that it is bending where it plugs into the TV. try unpluging it and plug it in and holding it. [right][snapback]263423[/snapback][/right] did that, its a straight shot the the tv and I already tired the unplug thing. Blah this sucks -Ti |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Nov 12, '02 From Webster Ma. Currently Offline Reputation: 1 (100%) ![]() |
a swift kick to the tv should do it.
Enthusiast ![]() ![]() Joined Nov 3, '04 From Colorado Currently Offline Reputation: 0 (0%) ![]() |
Did you try configure the video card to output NTSC signals rather than standard VGA signals that the graphic card may output?
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Jul 19, '04 From Los Angeles, CA Currently Offline Reputation: 2 (100%) ![]() |
I'm sure that there is a setting somewhere that you need to change. I have an ATI, but I've never tryed to plug into a TV before. Go to the ATI site and look it up there, and if you can't find it, send them an email, it will get fixed.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 30, '04 From So Cal Currently Offline Reputation: 13 (100%) ![]() |
Wow your old TV supports S-Video input? Or is your S-Video cable a S-Video to Composite cable adapter?
Your TV is pretty high-tech man ![]() I'm not sure why it's only displaying black and white images. An ATi 9200 should have no problem with the S-Video out. Is it your TV setting? -------------------- |
![]() Enthusiast ![]() Joined Sep 23, '04 From Stillwater, Ok Currently Offline Reputation: 0 (0%) ![]() |
try display settings/settings/makesureitson2screens/advanced - check the adapter then its settings you might try jacking w/ the color management or make sure the windows default isnt still on really low res&color.. just do the simple things first connections then auxillaries hard then soft. hope ya figure it out man good luck!!
-------------------- WAR HAS NEVER SOLVED ANYTHING...EXCEPT FOR THE ENDING OF COMMUNISM, FASCISM, NAZISM, AND SLAVERY.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 10, '04 From Shoreline, WA Currently Offline Reputation: 4 (100%) ![]() |
hmm, i have never heard of that problem, change your setting from clone to monitor/tv and make sure to set the resolution way down for the tv, but that should not affect the color.
do you ahve a s-video conector in the tv its self or do you have an rf modulator (what I use to convert s-video to a standard cable signal and add the sound into the cable to so i only connect the one cable) there avalible at radioshack or online for about $10. I bet that with your apex (cheapo) tv the s-video imput sux and cant figure out the color right or something. and be sure that your s-video cable is good, and all the pins on both sides are going in straight and all the way. because that would do it. I actualy have a 9200 se (I upgraded a wile ago) but I never seemed to have a problem using the RF modulator to get the tv to work, I did however cook the card many times (its just got that little heat sink that is not very good) the bigest problem I had was making sure to set up the acceleration to full in order to force it to send a full signal over to the tv, so i could get things in mediaplayer to display on the tv and not just a black screen. -------------------- ![]() |
ok, update for you helpers
TV is brand new. Its a cheapie, but its brand new. I'm running direct S-Video to S-Video. (and tom, thats been out for quite a while ??? My Wega has DVI-In.) All my settings are ok. I've used this same card before on another pc and it works. So far the only thing that keeps repeating itself on the net is "change your wires." Maybe my 12ft S is too long and maybe the TV is too cheap. I'll play around. Keep the ideas coming guys. Thanks -Ti |
I believe your S-Video port on your 9200 is a 7-pin (My 9600 is a 7-pin). If your S-Video cable is a 4-pin, you might be missing something. S-Video's got 2 composite signals, one Y, one C. Y signal transfers black and white colors (luminance) and the C signal transfers colors (chrominance). Also, does your TV has a SCART input? I found an article on ATi knowledge base regarding S-Video / SCART issue.
"Knowledge Base ATI Customer Care > Solve a Problem > Display > Black and White image on Television using 3rd party SCART adapter with an S-Video jack The information in this article applies to the following system configurations: TV OUT using 3rd party S-VIDEO to SCART adapter PAL or MULTISYSTEM TVs (most often found in European countries) The symptoms described are not specific to ATI products. This Infobase is provided for the convenience of users especially in Europe. The signal on the TV set may show up black and white using a 3rd party S-VIDEO to SCART adapter. A SCART connector only supports composite video. If you connect an S-VIDEO cable directly into a SCART adapter, the result will be a black and white signal, regardless of the type of graphics card being used. There are preferred S-VIDEO to SCART adapters from 3rd party vendors that will properly give you colour display. Third party S-VIDEO to SCART adapters are available from: http://www.svideo.com Please note: This site is a third party internet site on the World Wide Web. ATI provides such links for your convenience only, and is not responsible for the content of any site linked to or from this site. Links from this site to any other site do not mean that ATI approves of, endorses or recommends that site. ATI disclaims all warranties, express or implied, as to the accuracy, legality, reliability or validity of any content on any other site. If you decide to access any of the third party sites linked to this site, you do this entirely at your own risk." -------------------- |
To my understanding, SCART is a Euro thing. Both S-Video are 7-pin. Color has worked on other TV's with similar setups with the same card. I knowing, because my computer is a twin. I built the other for my best friend Jake. And Jake had his computer hooked up to my tv for movies quite a few times. However, it was a different machine, and different TV. Sony WEGA flat screen. I'd just try it on there except for both TV's are 27" and heavy as hell and my bedroom is upstairs. Blah.
-Ti |
Try it with a different tv
Lo-Fi Version | Time is now: February 24th, 2025 - 8:25 AM |
