> what sould be the best
post Apr 6, 2005 - 11:05 PM
RUNNIN-LOW
Joined Apr 4, '05
From ST PAUL, MN
what should i do if i want to have a better pull on 3rd gear.. im running a custom t-25 turbo in my car and yeah should i switch to a real ct26 turbo and just put away my custom set up. i pull hard on 1st and 2nd but i lose total power on 3rd and up..what should i do. switch to real ct26 or just keep want i got. i have a 95 gt 5sfte.
This post has been edited by RUNNIN-LOW: Apr 6, 2005 - 11:05 PM
post Apr 7, 2005 - 1:38 AM
Rjb23
Joined Feb 8, '04
From KY
QUOTE(RUNNIN-LOW @ Apr 7, 2005 - 4:05 AM)
[right][snapback]267536[/snapback][/right]
t3?
post Apr 7, 2005 - 2:49 AM
Drocay
Joined Oct 3, '02
From Va Team 6gc
agreed, t3 or hybrid is wut u need. hows the t25 thats wut i've been looking at for my 7afe either that or a t28bb
Team 6gc 2005
post Apr 7, 2005 - 10:21 AM
RUNNIN-LOW
Joined Apr 4, '05
From ST PAUL, MN
man ill tell you the one i have man its spools up fast. if i floor it it spool about 1300 rpm..and yeah now you know why i pull so hard on 1st and 2nd but see im planning on getting rid of it for a ct6 im just planning to change my set up.. but im still thinking about putting a t3 on like you say too. and yeah i want more power and people say i need a bigger turbo cause i have such a hugh motor compare to a small little turbo which isn't pushing enough power. but yeah its great man.
post Apr 7, 2005 - 1:13 PM
shin
Joined Aug 21, '04
From New York City
do you pics of your set up? cause i'm currently getting parts to turbo charge my 5sfe too. i'm gonna use the ct26 dual entry
~*MuH NeW RiDe*~
post Apr 7, 2005 - 10:32 PM
RUNNIN-LOW
Joined Apr 4, '05
From ST PAUL, MN
yeah i just have to redo my pictures and post it up on my profile.. so yeah..it will be up pretty soon
post Apr 7, 2005 - 10:53 PM
umm don't bother with ct26 if you have to upgrade might as well do it right
and get a T3
thats what i'm goin with to start?
post Apr 8, 2005 - 8:43 AM
RUNNIN-LOW
Joined Apr 4, '05
From ST PAUL, MN
alright then ill see what will happen im just woundring what will bring out more power
post Apr 9, 2005 - 3:05 PM
MonsterBOX
Joined Jan 8, '05
From Alabama
alot of people with the t3/t4 on 3ste and 5sfe say it takes a pretty long while to spool up...ur gonna have less power lower rpms and its gonna shift power up to 3-5....and ur not gonna spool up to full boost at 1300rpms anymore.....is there anyway to twin turbo a 5sfe so you can use the small turbo and the t3 together?
post Apr 9, 2005 - 3:59 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE(MonsterBOX @ Apr 9, 2005 - 12:05 PM)
[right][snapback]268823[/snapback][/right]
twin turboing a 4cyl is needlessly complex and expensive.
if you want a little better top end in 3rd, maybe consider a t28BB or something like that, im sure it will spool almost as fast
or you can get some good engine management and a nice external wastegate and with skilled tuning, make a t3 or t3/t4 hybrid spool up real quick.
This post has been edited by 97sccelica: Apr 9, 2005 - 4:01 PM
1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram
post Apr 9, 2005 - 5:36 PM
droptopGT
Joined Apr 12, '04
From Nj Team 6gc
go with t3
Team 6gc 2oo5
post Apr 9, 2005 - 11:23 PM
chucho
Joined Mar 23, '03
From New Orleans
QUOTE(97sccelica @ Apr 9, 2005 - 3:59 PM)
[right][snapback]268842[/snapback][/right]
listen to 97scelica, he knows his stuff
post Apr 10, 2005 - 9:10 AM
almost all the T3 series is too small for the 5s. IMO if money wasnt an object, i'd go for a T3/To4E hybrid with a 46trim compressor and a .48a/r for the turbine.
in that graph i plotted for 7 and 10 psi...good stuff, and as you turn up the boost it just gets better. i'd definetly sacrifice a little spool time for what that turbo will give ya wink.gif
::EDIT::: heres a plot of a 60trim T3, just so you guys can see what im talking about, this is the largest compressor in the T3 series.:
as you can see, your almost off the right side in the higher RPMS...anything smaller than a 60 trim T3 and your way off the map by 4500-5k...the exact reason your car falls on its face in the upper rpms, with ubber quick spool, your turbo is too small.
This post has been edited by presure2: Apr 10, 2005 - 9:14 AM
Lo-Fi Version Time is now: February 21st, 2025 - 1:23 PM
