> between GT and ST, noobie question PLEASE HELP
post Apr 14, 2005 - 9:04 PM
Ve1Ls1dEvolutioN
Joined Oct 19, '02
From Spring Valley, NY
is there a difference between GT and ST front spindle and hub?? i'm converting brakes from ST to GT. i bought cross drilled and slotted rotors but they wouldn't fit. i'm guessing i have to replace the backplate. but does anyone think i have to get new spindle and hub too??
thanx
alex
post Apr 15, 2005 - 9:54 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
The calipers are different... the backplates have nothing to do with the braking system... it's mostly a dust cover. The knuckles/spindle/hubs are all the same.
post May 13, 2005 - 9:37 AM
lazer_mjj
Joined May 11, '05
From Bristol, UK
Not really much point is there? I mean they are only a few mm bigger, save yourself the hassle buy st rotors and spend the change of braided brake lines for better braking
post May 13, 2005 - 10:37 AM
you can't swap between gt front and rear
you keep the ST front
and swap ST REAR DRUMS to GT REAR DISK
you have to keep front st rotors
or bump it up to 7th gen
post May 14, 2005 - 2:46 PM
dustin15brown
Joined Aug 17, '03
From Bloomington, Indiana
There should be a few threads about this already.. try a search
post May 14, 2005 - 7:15 PM
nowitzon
Joined Apr 6, '05
From homosassa,florida
quick one how much does it cost in total parts,labor etc to change over to disc brakes on a st
FOR 21 YEARS I DEALT WITH THE RAIN,
ONLY TO FIND OUT THAT I COULD STOP THE PAIN,
SO NOWITZON!!!
post May 14, 2005 - 8:00 PM
oooooooo
This post has been edited by playr158: May 14, 2005 - 8:01 PM
post May 17, 2005 - 7:02 AM
Illyont
Joined Apr 8, '05
From Norway
QUOTE(nowitzon @ May 14, 2005 - 7:15 PM)
[right][snapback]287039[/snapback][/right]
Get a European car smile.gif They come with disc brakes all around as stock.
post May 17, 2005 - 8:12 AM
no just get a GT
has nothing to do with country
GT=aw disk
ST= drum for the majority
post May 18, 2005 - 9:44 AM
red94celicagt
Joined Jan 28, '05
From Cincinnati, Ohio
QUOTE(playr158 @ May 17, 2005 - 8:12 AM)
no just get a GT
GT=aw disk
[right][snapback]287942[/snapback][/right]
yup, i got a '94 GT stocked brakes came with disks all around
Speeding is only Illegal...
If you Get Caught
post May 19, 2005 - 11:02 AM
S_C_M
Joined Mar 2, '04
From Louisiana, USA
I have GT front brakes on my ST. In order to use GT discs, you need to change the calipers and caliper mounting brackets over to GT parts. Brake lines bolt into the new calipers just fine. I don't have backing plates on my conversion.
I did this years ago, wish I'd have kept my Toyota boxes with the OEM part numbers, but a dealer should be able to supply the info.
post May 19, 2005 - 11:45 AM
yea GT works on the front
just need to replace the whole assembly
and there should only be backing plates on the rear for the e-brake
the front only has, caliper, disk, pads, bracket
post May 21, 2005 - 1:41 PM
DmVinny
Joined Feb 23, '03
From Florida
Can you take the rear disc brakes from a GT and put them in an ST?
post May 21, 2005 - 4:49 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE(DmVinny @ May 21, 2005 - 6:41 PM)
[right][snapback]290020[/snapback][/right]
Yes... you need the spindle/hub/backing plate/ebrake drum (should all be one piece), calipers /w brackets, rotors, ebrake cables, and brake lines. Essentially the entire rear assembly that bolts onto the lower suspension arms and strut. It's a direct swap over to the ST.
QUOTE(playr158)
The front has backing plates also. Why wouldn't they? Backing plates have nothing to do with the e-brake, they're mostly a dust cover. You also don't need the "whole assembly". You need the calipers with brackets, and rotors. That's it. Yet another example of you not knowing what you're talking about... rolleyes.gif
post May 21, 2005 - 11:10 PM
Ve1Ls1dEvolutioN
Joined Oct 19, '02
as far my situation i have no other choice but to upgrade my front ST to GT disc...i bought cross drilled and slotted rotors about 2 years ago and just gettin' a chance to put them now...not knowing i have to change the whole backplate,spindle,hub,calipers and everything...
backing plates on the front from a GT and an ST have two different part numbers...therefore 2 different size...backing plate for an ST is a little smaller than the GT...when i tried inserting just the rotors it would not spin and clear the backing plate
post May 22, 2005 - 12:18 AM
[QUOTE]
[/quote]
[/QUOTE]
i said exactly that just wat you call a backing plate i call a dust cover and you don't have to have a dust cover either
as in "whole assembly" i was refering to wat i stated
"caliper, mounting bracket, pads, rotor"
those are the necessities of changing st-gt
so i DO know what i'm talking about
stfu
This post has been edited by playr158: May 22, 2005 - 12:18 AM
post May 22, 2005 - 3:57 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE(playr158 @ May 22, 2005 - 5:18 AM)
stfu
[right][snapback]290158[/snapback][/right]
No no no... you STFU. You really have ZERO clue what you're talking about. You can't even differentiate what a dust cover and backing plate is. First you say the backing plate is part of the e-brake, then you say the fronts don't have them, now you're saying you refer to them as dust covers AFTER I tell you they have nothing to do with the e-brake system? That's all a backing plate does... is to cover the rotor. Woopie... Don't try to sound like a smart ass calling things all sorts of crazy names. As for "whole assembly"... whole assembly is the spindle/knuckle, hub, calipers, rotors, basically everything minus the suspension arms and strut. AGAIN, more proof you just don't know jack sh!t. You continually speak out of turn and pass off completely WRONG information. You are the one who really needs to just Shut the f*ck up.
QUOTE(Ve1Ls1dEvolutioN)
You don't need to change any of that for the fronts... you only need calipers. For the rears, you'll need the entire assembly.
Like I said, they're more or less dust covers. You can remove them completely (fronts only), or just bend them back to clear the rotor. No big deal. They're usually removed when big brake kits and such are installed.
post May 22, 2005 - 3:40 PM
FAQdaWorld
Joined May 24, '03
From Milton, Delaware
Should i call the fire department? someone may have just got burned...
AIM : FAQdaWorld
post May 22, 2005 - 6:43 PM
Cutrara
Joined May 6, '05
From PA
The internet is serious business.
Good luck with the brake conversion.
post May 23, 2005 - 10:43 AM
Ve1Ls1dEvolutioN
Joined Oct 19, '02
are the brake line for the front the same in a GT and ST??
Lo-Fi Version Time is now: November 24th, 2024 - 8:52 PM
