Smoked, Blown Sub :( |
Apr 19, 2005 - 11:09 AM |
Enthusiast Joined Feb 8, '04 From Thornton, CO. Currently Offline Reputation: 1 (100%) |
I got a dual 2ohm 10" Alpine type S (900watts peak), with a 800(peak) watt kenwood amp (Last years model). It recently smoked the sub at normal playing levels. The gains were set minimally as was frequency with the bass boost on (12db). The guys at the shop i bought everything at didnt know what could of caused it (Everything was properly adjusted and installed), any ideas?
-------------------- Fred
"...Armed with backbone and busted zoo gates, promising you from the bottom of my harmonica pocket - FOREVER - you will never have another lonely holiday..." |
Apr 19, 2005 - 11:23 AM |
Enthusiast Joined Aug 20, '03 From Annapolis, Md Currently Offline Reputation: 5 (100%) |
bad sub. I got one that blew with in 2 weeks, after norm playing, it was rockford, but then replaced it, and the other ones are perfect.. havnt had a problem, but i barey ever use them.
Apr 19, 2005 - 11:32 AM |
Enthusiast Joined Feb 19, '04 From austin tx Currently Offline Reputation: 1 (100%) |
Peak power means nothing, and just because the gains were set "minimally" doesnt mean they were set right. You fried the voice coil, so it was either clipping, overpowered, or like digndoug said, you just got a faulty sub. If you bought it from a shop and had them install it, ask for a new one and ask them to make sure the gain is set right, as well as having a correct load on the amplifier. Also, i would probably have the bass boost turned off.
Apr 19, 2005 - 5:27 PM |
Enthusiast Joined Mar 19, '04 From Scottsdale, Az Currently Offline Reputation: 2 (100%) |
I kept blowing my alpine amp and sending it back for warranty. My problem was the heat. I couldn't get cool air in my trunk, and during the summer it was probably 150 degrees in there. I switched to fosgate, and that solved the problem.
Apr 24, 2005 - 5:11 PM |
Enthusiast Joined Apr 14, '05 From garfield hts. O-HI-O Currently Offline Reputation: 0 (0%) |
my fosgate amp running my subs always over heats but my infinity right next to it never does?? and neither are fan cooled
Lo-Fi Version | Time is now: November 28th, 2024 - 8:41 PM |
