> burning smell, coming from engine bay?
post Apr 19, 2005 - 10:02 PM
ummmx2
Joined Nov 6, '04
well after todays drive home from school, and dropping off all my friends (4), i come home and smell this burning smell coming from my car. it smelled really bad, and was pretty strong. i smelled this smell before, but thought nothing of it since it went away, but this is really strong. not sure what could be causing this? im not sure if my friends put that much extra strain on the engine or wut? but i didnt think it would start to burn?
post Apr 19, 2005 - 10:09 PM
spunky393
Joined Apr 22, '04
From illinois
is it a manual?
The most important lesson I learned from Karate-Dō Kyōshan“You can not be what you do not believe you are”
post Apr 19, 2005 - 10:10 PM
hellsyphon
Joined Dec 3, '04
From torrance, ca
Can you describe the smell? Like acrid and smokey?
post Apr 19, 2005 - 10:41 PM
celicagurl152003
Joined Oct 12, '04
From Montgomery, AL
well you could be burning oil or you could have some loose wireing that is melting/burning
post Apr 20, 2005 - 11:28 AM
ummmx2
Joined Nov 6, '04
its an auto. it smells almost maybe like bad burning rubber, but im pretty sure its not my tires.
post Apr 20, 2005 - 11:37 AM
JazViper
Joined Nov 6, '03
From Finland
check your brakes.. like go near them and see if smell comes from disc, i had like that, my clinder was dragging little and disc heated enough to put metallic smell in my car occasionally after long drives.
post Apr 21, 2005 - 1:41 AM
coldbluesteel
Joined Jul 9, '04
From Las Vegas USA
Ive got a 94 GT with 5 speed and I also have a burning problem. It's not the clutch, I am all to familiar with that smell! I do have a small oil leak and exhaust smokes slightly on start up sometimes. I had the motor pulled to do alot of build up about 40k ago, and no problems until very recently. I also changed over to cross drilled rotors, high temp painted calipers, and kevlar ceramic pads (Axxis ultimate) about 5k ago so It's not my brakes. Any suggestions would be helpful! As for Ummmx2, is your car lowered if so you may have been rubbing rubber with all the extra weight. Also you should check your belts for sign of wear. Hope this helps!
This post has been edited by coldbluesteel: Apr 21, 2005 - 1:52 AM
Lo-Fi Version Time is now: November 28th, 2024 - 11:16 PM
