Water pump differences, ST185 & ST205 |
Apr 21, 2005 - 9:41 PM |
Moderator Joined Apr 17, '03 From Rockland NY Currently Offline Reputation: 15 (100%) |
Is there any difference between the st185 & st205 water pumps ?
Thanks Def -------------------- I will return one day. |
Apr 22, 2005 - 12:06 AM |
sounds like the type of thing the mr2oc.com guys would know.
Apr 22, 2005 - 1:58 AM |
Waterpumps attach to the block... so they should interchange just fine even if they are slightly different.
-------------------- "It's ok to be naked girl... I'm an artist!"
Apr 22, 2005 - 3:43 PM |
QUOTE(Kwanza26 @ Apr 22, 2005 - 1:58 AM) Waterpumps attach to the block... so they should interchange just fine even if they are slightly different. [right][snapback]276088[/snapback][/right] What about the fact that the 205 is water cooled and the 185 is not ? I think this would make a difference, no ? Thanks, DEF -------------------- I will return one day. |
Apr 22, 2005 - 3:48 PM |
QUOTE(defgeph @ Apr 22, 2005 - 8:43 PM) What about the fact that the 205 is water cooled and the 185 is not ? I think this would make a difference, no ? Thanks, DEF [right][snapback]276447[/snapback][/right] Hehe... that's refrence only to the intercoolers. The engine cooling system is mostly separate from that... -------------------- "It's ok to be naked girl... I'm an artist!"
Apr 22, 2005 - 3:50 PM |
are you sure cause if you look at the BGB of the coolant flow it shows that the st205 shares the water pump for the rad and intercooler.
Apr 22, 2005 - 3:53 PM |
Apr 22, 2005 - 3:58 PM |
my guess is that the pump is the same. i dont think the st205 intercooler uses coolant from the motors supply. it has its own heat exchanger, pump and its own coolant supply. so buying an st185 waterpump would work fine for your setup.
This post has been edited by lagos: Apr 22, 2005 - 3:59 PM -------------------- 15PSI - 30MPG - Megasquirt Tuned
Apr 22, 2005 - 3:59 PM |
Apr 22, 2005 - 4:01 PM |
I guess I'm getting confused because I see the red hoses in the last pic.
So the only thing to worry about is the intercooler water pump? as far as availablity. -------------------- I will return one day. |
Apr 22, 2005 - 4:02 PM |
If you look at that diagram... the waterpump does not attach to anything aside from the pump housing. The pump housing is where the inlet, therostat, and various coolant lines are attached to. Let me also clearify, there are two parts to a complete waterpump. The housing, and the pump itself. When you buy a waterpump, usually you'll only buy the pump and the housing is re-used. I'm pretty certain the waterpumps themselves are interchangeable... but there may be differences in the pump housings...
Apr 22, 2005 - 4:06 PM |
do you know if the intercooler pump ever fails could someone rebuild it ?
Apr 22, 2005 - 4:18 PM |
yeah...dont worry too much about the intercooler pump. i think you can even you the 4th gen alltrac pump if you really had to.
Apr 22, 2005 - 7:46 PM |
Enthusiast Joined Nov 16, '04 From UK Currently Offline Reputation: 0 (0%) |
QUOTE(defgeph @ Apr 22, 2005 - 3:50 PM) are you sure cause if you look at the BGB of the coolant flow it shows that the st205 shares the water pump for the rad and intercooler. [right][snapback]276458[/snapback][/right] No it flippin doesn't...... -------------------- JDM ST205
Blitz Spec NUR Exhaust, somewhere over $1000 Needing another one 18000 miles later, bloody annoying. |
Lo-Fi Version | Time is now: November 28th, 2024 - 11:57 PM |
