Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 3, '05 From Hollywood, FL Currently Offline Reputation: 0 (0%) ![]() |
Well, it was raining a few days ago, and I went to use my rear windshield wiper, no problems. Then, yesterday I noticed my rear window was pretty dirty so I decided to use the washer nossle in the back to clean it off, but nothing was coming out when I used the switch. It was working before, but not I have no idea what might have gone wrong. If anybody else has ever had this situation please help me. Thanks.
-------------------- To live, is to suffer
To survive, thats to find meaning, in the suffering.... ![]() |
Enthusiast ![]() ![]() ![]() ![]() Joined Nov 22, '04 From FL Currently Offline Reputation: 1 (100%) ![]() |
i had that problem on my 87 celica waaaay back. That means that along the waysomething happened to the tube that comes from the front of the vehicle and carries water to the back. It may be clogged, jammed by a hatch door etc. check the top of your hatch and follow the tube. you may have to open most of your car. Second option would be to disconnect your wter bottle, attach a air compressor to the tube and let it blow everything out on both ends. Might take awhile. Repeat same procedure from both sides, then pump in the water into the tube system and make sure it comes out freely out of 1 end, while you are pouring it/better yet using a water pump from the other.
See that is one of the reaspons why my 6gc is not a hatchback -------------------- Captain Pessimist
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 21, '04 From New York City Currently Offline Reputation: 0 (0%) ![]() |
both my front and rear washer nozzles are not working.... my mechanic said it might be the pump or something... but i didn't fix it yet...
Enthusiast ![]() ![]() ![]() Joined Mar 20, '04 Currently Offline Reputation: 3 (100%) ![]() |
QUOTE(bloodrain @ Apr 26, 2005 - 12:53 PM) Well, it was raining a few days ago, and I went to use my rear windshield wiper, no problems. Then, yesterday I noticed my rear window was pretty dirty so I decided to use the washer nossle in the back to clean it off, but nothing was coming out when I used the switch. It was working before, but not I have no idea what might have gone wrong. If anybody else has ever had this situation please help me. Thanks. [right][snapback]278220[/snapback][/right] same thing happened to me i've been without for almost two years now. |
QUOTE(yarik83 @ Apr 26, 2005 - 10:58 AM) i had that problem on my 87 celica waaaay back. That means that along the waysomething happened to the tube that comes from the front of the vehicle and carries water to the back. It may be clogged, jammed by a hatch door etc. check the top of your hatch and follow the tube. you may have to open most of your car. Second option would be to disconnect your wter bottle, attach a air compressor to the tube and let it blow everything out on both ends. Might take awhile. Repeat same procedure from both sides, then pump in the water into the tube system and make sure it comes out freely out of 1 end, while you are pouring it/better yet using a water pump from the other. See that is one of the reaspons why my 6gc is not a hatchback [right][snapback]278254[/snapback][/right] thanks alot bro, i'll try it out. -------------------- To live, is to suffer
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 17, '03 From Bloomington, Indiana Currently Offline Reputation: 62 (98%) ![]() |
my front one doesn't work, but i think the last guy to detail my car (a friend who needed money so i let him do it) got like wax on it... weird i know
My rear washer nozzle wasn't working either. I would turn the knob but nothing. So, played around and I solved the problem kinda,
EVERYONE TRY THIS : I squirt the front washers (they work fine) and hold them on and then turn the rear squirt knob at the same time. The rear nozzle squirted for the first time since I have had the car. Just play with it. -------------------- |
Lo-Fi Version | Time is now: February 24th, 2025 - 7:32 AM |
