> TRD VS TWM
post May 1, 2005 - 6:15 PM
Drew-887
Joined Jan 5, '05
From Upper Darby, PA(5 min away from Philly)
Who do you guys think makes a better short shift TWM or TRD?
post May 1, 2005 - 6:59 PM
Consynx
Joined Dec 25, '02
From Pittsburgh/Clairton, PA
twm is shorter, but trd comes w/ shifter assembly.
post May 1, 2005 - 7:12 PM
CheesyLobster
Joined Jul 19, '04
From Los Angeles, CA
twm, its shorter and cheaper, and imo, less of a hassle to install.
post May 1, 2005 - 9:59 PM
Punch
Joined Jan 29, '04
From Brooklyn moved to Miramar Florida
twm is srorter & ezer to install....
post May 1, 2005 - 10:44 PM
Bigmeanbulldog55
Joined Jun 1, '03
From WV
Make your own. Just take a hacksaw to your shifter. Shorter shifts.
Live Free, Be Happy
post May 2, 2005 - 12:25 AM
there have been a few debates about these in the past. Do a search for "short shifter" and do some reading. Also the 7th gen short shifter fits fine and is a lot cheaper.
post May 2, 2005 - 12:33 AM
juBz86
Joined Aug 18, '04
From NJ
yea i'm sure you'll find alot of info if you do the search cuz this has been covered alot of times. just be patient and read the posts biggrin.gif
post May 2, 2005 - 1:30 AM
QUOTE(Bigmeanbulldog55 @ May 1, 2005 - 8:44 PM)
[right][snapback]281164[/snapback][/right]
That isn't the same as getting a true short shifter. A short shifter extends the lever below the fulcrum.
post May 2, 2005 - 11:27 AM
i have the twm. its very very short, but you get used to it quick. i tried the trd one and i like that one too because its a little longer. either one you go with will be great tho.
post May 2, 2005 - 11:58 AM
IMO you cant really compare the 2, theyre 2 totally diffrent things
the TWM is a short shifter, IE SHORTER SHIFTER LENGTH
the TRD is a QUICKSHIFTER not shorter than stock, just quicker throw
the TRD is made to keep your hand CLOSER to the steering wheel, where it SHOULD be when your not shifting.
/rant wink.gif
post May 2, 2005 - 12:50 PM
Bigmeanbulldog55
Joined Jun 1, '03
From WV
QUOTE(Coomer @ May 2, 2005 - 2:30 AM)
[right][snapback]281224[/snapback][/right]
I knew there had to be something about them more than just the shorter shaft. I also knew that it was not as good of an idea to just saw off the shifter. I never knew exactly why though.
QUOTE(presure2 @ May 2, 2005 - 12:58 PM)
/rant wink.gif
[right][snapback]281364[/snapback][/right]
Anyone comferm this? TRD would most definately be my choice if this is the case. Is is really better for preformance driving?
Live Free, Be Happy
post May 2, 2005 - 2:22 PM
i compared my twm to mannys trd one. my throw is a lot shorter. you can basically just rest your arm on the console and flick your wrist to change gears. but since the stick is so short, you have less leverage. so sometimes the trd one would make it easier to change gears but with a little bit of a longer throw.
basically
trd, great shifter, easy great changes, slightly longer throw then twm
twm, super short throw, but less leverage to work with, makes it easy to change gears with cups in the cup holder.
post May 2, 2005 - 5:30 PM
Drew-887
Joined Jan 5, '05
QUOTE(Batman722 @ May 2, 2005 - 12:25 AM)
[right][snapback]281204[/snapback][/right]
Cool, you use a 7th gen Shifter! smile.gif I think I might just use that one or I might just go with the TRD one.
This post has been edited by Drew-887: May 2, 2005 - 5:33 PM
post May 2, 2005 - 7:15 PM
Akimbo
Joined Jun 30, '03
From O-town, FL
I got the TRD cuz it has a shifter assembly which rulez0rs for my auto -> manual swap. Plus it's TRD.
- Ryan
aim: rkgreen04
post May 2, 2005 - 7:51 PM
Consynx
Joined Dec 25, '02
^what he said
plus i foudn it for $140+shipping
post May 3, 2005 - 11:32 AM
urbandork
Joined Jul 16, '04
From Los Angeles
QUOTE(lagos @ May 2, 2005 - 7:22 PM)
twm, ... makes it easy to change gears with cups in the cup holder.
[right][snapback]281455[/snapback][/right]
Very very ture and im glad i got one.
post May 3, 2005 - 11:43 AM
urbandork
Joined Jul 16, '04
From Los Angeles
just found this
http://toyotanation.com/forum/t77582.html
10% dis. on twm celica shifters. Promo code inside. Plus like always free shipping.
post May 3, 2005 - 11:49 AM
TRD6GC
Joined Nov 17, '03
I originally cut my shifter with a hack saw, so short that my shift knob wouldnt go down all the way and got in the way when i shifted. It made it shift faster but then i got the TRD Quickshifter and even tho it is higher, it shifts faster. I would go with TRD because, well it's TRD. It's like a stock part. It replaces the whole shifter assembly and not just the shifter rod and comes with steel bushings to replace the stock rubber ones (where it bolts to the car) so it also sits sturdier. Plus you get the sweetest shift knob ever.
post May 3, 2005 - 11:58 AM
Kadett
Joined Mar 17, '05
From The Netherlands
How much for the TRD quickshifter. Maybe thats my next to buy part after my projectors!
post May 3, 2005 - 2:19 PM
Consynx
Joined Dec 25, '02
from a dealer here ~$200
unless they're kewl
but dealers oversears have beaten our us prices before, so maybe $150
Lo-Fi Version Time is now: February 22nd, 2025 - 9:03 AM
