Enthusiast ![]() ![]() ![]() ![]() Joined Sep 18, '04 From Manitoba, Canada Currently Offline Reputation: 1 (100%) ![]() |
I have rust on the inside of both of my door panels all along the bottom. Is there anyway I can fix this or at least prevent it from getting worse? I'd take it to a body shop but i really don't have the money right now. Thanks guys, heres pics:
![]() Enthusiast ![]() ![]() ![]() Joined Feb 19, '04 From austin tx Currently Offline Reputation: 1 (100%) ![]() |
thanks
Enthusiast Joined Apr 24, '05 Currently Offline Reputation: 0 (0%) ![]() |
Try POR-15. This stuff is the best.
alright so i started sanding down the rust, all is well, got down to bare metal, no holes in it, just surface rust. but here's my problem. the black moulding around the door, there rust beneath that too, can i take it off? if i take it off will it go back on? i don't want to fix the other rust and just let that rust take off.. thanks for your help in advance guys, much appreciated.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Nov 4, '02 From Hecho en la Republica Dominicana/Living in NJ Currently Offline Reputation: 0 (0%) ![]() |
QUOTE(95gtschick @ May 8, 2005 - 4:12 PM) alright so i started sanding down the rust, all is well, got down to bare metal, no holes in it, just surface rust. but here's my problem. the black moulding around the door, there rust beneath that too, can i take it off? if i take it off will it go back on? i don't want to fix the other rust and just let that rust take off.. thanks for your help in advance guys, much appreciated. [right][snapback]284347[/snapback][/right] na just pull it off and u can snapp it back on .. -------------------- |
Enthusiast ![]() ![]() Joined Feb 15, '04 From saskatoon, sk Currently Offline Reputation: 0 (0%) ![]() |
QUOTE(IfOnlyIHadAMoneyTree... @ May 4, 2005 - 9:09 PM) Try POR-15. This stuff is the best. [right][snapback]282525[/snapback][/right] i think POR-15 is an undercoating, meant to prevent rust. applying it to an already rusty area isnt going to help at all |
QUOTE(macavely @ May 8, 2005 - 4:55 PM) QUOTE(95gtschick @ May 8, 2005 - 4:12 PM) alright so i started sanding down the rust, all is well, got down to bare metal, no holes in it, just surface rust. but here's my problem. the black moulding around the door, there rust beneath that too, can i take it off? if i take it off will it go back on? i don't want to fix the other rust and just let that rust take off.. thanks for your help in advance guys, much appreciated. [right][snapback]284347[/snapback][/right] na just pull it off and u can snapp it back on .. [right][snapback]284358[/snapback][/right] are you sure? lol i don't want to wreck anything -------------------- ![]() |
Lo-Fi Version | Time is now: February 24th, 2025 - 2:08 AM |
