> Replacing Drum Shoes, ?
post May 21, 2005 - 1:14 PM
JoKeRkId613
Joined Apr 25, '03
From Miami, FL
hey, i found out what was wrong with my braking system. i need to replace the shoes on both rear drums. can anyone tell me everything i need to know to change the shoes(pads)? do i have to take the drum off the car? how do i do this? and how do i change the shoes? step by step descriptive instructions asap would be nice. thanks a lot!
post May 22, 2005 - 1:29 AM
Hanyo
Joined Aug 16, '03
From Bay area
1)remove the back wheels
2)pry the drums off
some times there is a philps screw holding the drum on.. some times not..
3) inspect the drum.. and see if there is a ledge on the inside of the drum.. replace or get the drum turned if needed. ( caution do not inhale the brake dust!!)
4) remove the springs at the bottom of the brake system and this should release the drum pads
5) remove this screw device at the bottom of the system. its like this extender thing; You need to retract it together. you should be able to tell what this is. Its the only thing that has threads on both sides and a knotched quarter thing at the center..
6) install new pads and springs..
7) install drum and repeat what you did on the other side of the car
8) after both the drums have been changed.. stomp on the brakes several times so the drums can adjust it self to the new pads.
I would be carefull about changing drum pads. they are not easy to do and require some skill.
good luck.
post May 25, 2005 - 5:02 AM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
Option B: buy a Haynes or Chilton's manual for a similar guide with pictures and torque specifications as necessary.
post May 25, 2005 - 5:25 AM
Dr_Tweak
Joined Mar 31, '04
From Summerville, SC
Option C: Screw the brake drums and shoes and do a rear disc conversion.
Click here to see my swaps
drtweak@phoenixtuning.com
post May 25, 2005 - 6:44 AM
JoKeRkId613
Joined Apr 25, '03
From Miami, FL
hey raven, you selling any disc brake components. i would love option c.
post May 27, 2005 - 4:44 PM
nowitzon
Joined Apr 6, '05
From homosassa,florida
new disc brakes are extremely expensiveid do it in a minute but dont have that kinda cash
FOR 21 YEARS I DEALT WITH THE RAIN,
ONLY TO FIND OUT THAT I COULD STOP THE PAIN,
SO NOWITZON!!!
post May 27, 2005 - 6:09 PM
mentat
Joined Apr 25, '05
From Canada
I tryed doing this with the manuals and i found them very confusing.
My suggestion would be to take of both rear wheels and drums and use one side for reference. Worked perfect for me smile.gif
Lo-Fi Version Time is now: November 29th, 2024 - 3:42 AM
