Tap for oil, 7afte |
May 25, 2005 - 10:26 AM |
Enthusiast Joined Oct 15, '04 From Muskegon Currently Offline Reputation: 0 (0%) |
is there a sertain spot oh a 7afe where i should drill the hole for my oil return line?
May 25, 2005 - 10:34 AM |
QUOTE(nk_pimpin18 @ May 25, 2005 - 8:26 AM) is there a sertain spot oh a 7afe where i should drill the hole for my oil return line? [right][snapback]291561[/snapback][/right] i would do the front of the pan where the drain plug is located and as high up as you can go check my HOW TO turbo a 7afe here This post has been edited by nik: May 25, 2005 - 10:36 AM -------------------- yea your 3sgte is cool but ill stick to my 7agte
May 25, 2005 - 8:14 PM |
thanks alot, did you drill yours or did you buy a new one. im kinda scared to drill it dont want any metal shavings in my oil
May 26, 2005 - 9:06 AM |
QUOTE(nk_pimpin18 @ May 25, 2005 - 6:14 PM) thanks alot, did you drill yours or did you buy a new one. im kinda scared to drill it dont want any metal shavings in my oil [right][snapback]291847[/snapback][/right] just remove the whole pan then drill and clean it out then reinstall it -------------------- yea your 3sgte is cool but ill stick to my 7agte
May 29, 2005 - 3:04 PM |
Enthusiast Joined Sep 9, '02 From Scranton, Pa Currently Offline Reputation: 7 (100%) |
after looking at the celica motor and seeing how other companys plumb the oil drain, id look for a spot higher into the block. when i get motivated (prolly months from now) ill try to boost this motor again.
Lo-Fi Version | Time is now: November 28th, 2024 - 7:45 AM |
