8 Speaker Stereo Issues...., NEED SOME HELP!! |
Apr 18, 2003 - 4:13 PM |
Enthusiast Joined Oct 13, '02 From Blairstown, New Jersey Currently Offline Reputation: 6 (100%) |
I have a 94 GT with the double-din, 8-speaker premium audio setup that has an amp built in to it all. My stock CD-player doesnt work anymore....it doesnt read the CD correctly, so i decided to replace it.
Noww....I spent almost the entire day at Circuit City trying to get a 50w x 4 Panasonic head unit installed into it, only they said that they cant install it because of the 8 speakers and how it wires up.....the wiring harness doesnt work because of the amp. The guy i dealt with was an honest guy, but he said that for it to work, he would have to install two more amps to power the in-door subs up front and the two tweeters. Apparently the head unit could only power the front two mid speakers and the rear two without running into any problems with the ammount of OHM's each speaker was recieving.....thus, no splitting wires to power the subs and tweeters unless i wanted to blow the head unit. i was quoted almost $950 total for the head unit, installation, and amps alone.....just to get the stock speakers to work correctly!!! So here are my questions- 1.) Does anybody else have the 8-speaker system and gotten a new head unit?? If so, how did you fix it??? 2.) Is this guy right?? 3.) Should i just get a new double-din unit from Toyota that i can just swap to avoid all this, or is there some way i can fix my existing head unit?? Any help will be greatly appreciated......ive had a long day, and i need some knowledgable people to set everything straight for me. Thanks. -Corey -------------------- 3rd gen ST205 3SGTE - Alive and boosting. |
Apr 18, 2003 - 6:53 PM |
Thanks Matt, i guess what this guy said was that all 8 speakers were 4 ohm each, and since i could only power four speakers via the head unit, i would have to get two additional amps to power the subs and tweeters seperately......then all 8 would work. So could i use a 4-channel amp and split the front channels 3 ways, or does the ohm rating on the speakers make a difference?
Apr 18, 2003 - 9:10 PM |
awesome.....as long as you know it works i might consider doing that. Its either that or i try to get my stock head unit repaired so it plays CD's again......thats the only thing im really looking to do with all this, cuz im tired of using a crappy tape adaptor with my walkman Ill have to compare prices that way i can leave enough money for other mods this summer. But once again, thanks for the advice
Apr 20, 2003 - 10:30 AM |
I actually found a guy near me that repairs car stereos.....i looked all over the place and apparently he does good work. So i think that i might do that. Now my question is- would i be able to send a signal out of my stock headunit to add on an amp and sub? The stereo in my car now is the stock double-din headunit (CD/cass/radio with amp unit underneath), if that makes a difference.
Lo-Fi Version | Time is now: November 24th, 2024 - 10:36 AM |
